by RetireeJay » 2019-Sep-Mon-14-Sep
Did you get your hex file from this location?
If so, did you choose a version labeled Rev D? If you chose a Rev F version, then not only will the Z probe logic be inverted but there will be other problems as well. Rev F and Rev D boards are software-incompatible.
Assuming that you downloaded the correct file for a Rev D board, then you should try messaging the author of the compiled hex file on github with the error report or raise an "Issue" on the site. You won't be the only person with this problem, and it should get fixed at the source. It looks like the author has been fairly active, so hopefully he'll respond. The fix inside his source code is extremely simple, just a single line. But he has his toolset configured to build the hex file correctly according to his own particular preferences, so someone else trying to create the hex file might not be able to create a good one that fits within the available memory.
Another option is to do a hardware fix. There are probes with the opposite polarity of signal output and even probes which can be configured to give you whatever flavor output you want.
