Hey All,
I've had my Printrbot Simple Maker(1405) for a few years now and have had the same problem from the start. The 2mm spacer provided for setting the Z-axis has never worked for me, I was wondering if anyone else has run into this problem? My printer seems to work best with a gap of around 1.7mm. I have been setting my z-axis by zeroing the z as instructed but, rather then using the spacer I have been forced to manually set the auto-leveler by hand. Basically I loosen it up and set it to the depth where the red light just comes on, this seems to be it's intended function unless I'm mistaken. I might accuse my sensor of being faulty but I had to get a new board a year or two after getting my printer and with the new board they had also sent me a brand new auto-level sensor, which made no difference when shimming the z-axis.
Another issue with the auto-leveler I'm not understanding is why it zeros fine at the home position of the y-axis but when extended out during the auto-level process the nozzle hits the bed. Now I would assume that when it hits the bed it would force the z to lift towards the front and move lower towards the back unless I'm mistaken, but it seems to do the exact opposite moving tighter where it's closer and further where there is a greater gap. Something I notice in Repetier-Host makes me wonder if it reads the y-axis backwards somehow. The reason I suspect this is from the y-axis' home position I can not move the head out by using positive values when jogging the y, it only moves forward using negative values, which in turn requires me to trick the program by first using a max positive value and then and only then will I be able to move the head out using negative values. Is this normal? If not any advice on fixing it would be greatly appreciated.
