by protom » 2019-Mar-Sat-19-Mar
I ended up recrimping all the cable to connect to a SKR v1.1 with marlin 2.0 just to realize the problem was a cable heat shrink extension on two of the cable motors got used by friction and was creating a bad connection...
stupid me
anyway I now have a Skr v1.1 with marling 2.0 and TMC2208 x and y are working fine but z is shaking and not moving the motors if I set it to step per unit 2500 if I go around 500 it works but logically moves 1?10th of what it should ( for 100mm command it will move 10mm..)
also have some issues with extruder skipping..
I Suspect it has to do with my axis step per unit default max federate and max acceleration...
these are my current settings :
#define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 2500, 96 }
* Default Max Feed Rate (mm/s)
* Override with M203
* X, Y, Z, E0 [, E1[, E2[, E3[, E4[, E5]]]]]
#define DEFAULT_MAX_FEEDRATE { 200, 200, 3, 14 }
* Default Max Acceleration (change/s) change = mm/s
* (Maximum start speed for accelerated moves)
* Override with M201
#define DEFAULT_MAX_ACCELERATION { 2000, 2000,50 , 2500 }
I am using m8 threaded rod with the original dual nema17 for Z
and the V1 aluminium direct drive extruder for E...
any idea
Original Printrbot operational July 2012
upgraded to custom XL printbrot 360x360x780 built platform
Flashforge creator pro with flexion extruder
M3D Promega compound extruder
XYZ COLOR 3D mini
polymaker polysher
"My next printer is..." SLA printer
