Hi,
I don't know if anyone else has had this issue, I am using Cura 15, with a Ubis 13S hot end. I started getting really erratic hot end readings in Cura, variances of up to 20 degrees during printing. I ran a PID loop and got these results, this is with no filament.
I was going to input the PID settings as per the instructions on another post on the forum, but the KP value looks really low, does this look right to anyone? And are there any other issues I should be checking for?
> M303 E0 S210 C8
< PID Autotune start
< bias: 137 d: 117 min: 194.12 max: 210.63
< bias: 133 d: 121 min: 192.10 max: 210.63
< bias: 112 d: 112 min: 206.25 max: 211.91
< Ku: 50.35 Tu: 12.45
< Clasic PID
< Kp: 30.21
< Ki: 4.85
< Kd: 47.03
< bias: 111 d: 111 min: 206.13 max: 211.88
< Ku: 49.23 Tu: 13.50
< Clasic PID
< Kp: 29.54
< Ki: 4.38
< Kd: 49.84
< bias: 137 d: 117 min: 188.28 max: 220.54
< Ku: 9.24 Tu: 13.37
< Clasic PID
< Kp: 5.54
< Ki: 0.83
< Kd: 9.26
< bias: 101 d: 101 min: 197.70 max: 224.29
< Ku: 9.67 Tu: 14.94
< Clasic PID
< Kp: 5.80
< Ki: 0.78
< Kd: 10.84
< bias: 137 d: 117 min: 189.14 max: 227.00
< Ku: 7.87 Tu: 16.12
< Clasic PID
< Kp: 4.72
< Ki: 0.59
< Kd: 9.52
< PID Autotune failed! Temperature too high
