Simple Metal Suddenly Printing/Moving Faster
Postby ktfergus » 2018-Apr-Mon-18-Apr
I had an odd experience with my Simple Metal today; after two normal prints, I started a different part with the same slicer settings but the printer moved/printed almost twice as fast as it should have. The ETP for the part was 1h17min & the print finished in less than forty. I tried a different part with different slicer settings & the same thing happened; almost like the settings were being overwritten by the firmware (I use Repetier Host & double checked to make sure I didn't have the override box checked).
I cycled the power on/off, resliced the part & thankfully everything is now back to normal. In over three years of almost daily printing I've never seen this before, & I was curious if anyone else has ever seen their bot act like this. Any thoughts on a cause? Could it have been a clock/processor issue?
ktfergus
Re: Simple Metal Suddenly Printing/Moving Faster
Postby RetireeJay » 2018-Apr-Mon-19-Apr
That's a new one on me!!!
Postby Mooselake » 2018-Apr-Wed-14-Apr
Could you have moved the Repetier-Host speed slider accidentally? It returns to 100% when you exit and restart the program.
If the print quality was good perhaps you want to bump up your speeds? I use lower speeds for external perimeters (40mm/s iirc) to get a nicer surface finish, and 100mm/s or more for most of the rest where it doesn't show. Of course that's on a highly tweaked plywood plus, not one of the metal guys.
Postby ktfergus » 2018-Apr-Wed-17-Apr
Yup, Moose, that's exactly what must have happened. I think what threw me off is that the slider is labeled "Feedrate" but sure enough it was at 183! What's odd is that after I restarted the bot the "feedrate" was still at 183 but my next print ran at the usual speed. I've since played around with the slider mid-print & it recreates what I experienced, so now I'll keep a closer eye on the sliders.
The quicker speed definitely affected the quality, but I was printing PETG which doesn't like high speeds (especially on bottom or top finish layers).
ktfergus
Users browsing this forum: Bing [Bot] and 2 guests
