Ubis 13S tips
Ubis 13S tips
Postby Buchnerb » 2018-Feb-Fri-15-Feb
Does anyone know of an alternate source of supply for Ubis 13S tips? They have been unavailable from PB in .3 and .4mm for some time and I just put in my last one. From the looks of their web site it looks like they are closing out the home machine stuff. I may have to break down and make my own. Does anyone know the thread size off hand for the 13S tips?
Bruce
Wanhao D7 UV liquid resin printer
PrintrBot Simple Metal w/Heated Bed Upgrade
CNC Lathe Sherline
CNC Mill Sherline
Grizzly 11x26 lane
South Bend 9x36 Lathe
Rockwell Mill
Atlas Shaper
Buchnerb
Ubis 13S tips
Re: Ubis 13S tips
Postby ktfergus » 2018-Feb-Sat-18-Feb
I did a little digging & here's what I came up with. Ubis 13s nozzles have M6 x 1 thread: Here's a link to the post.
As you'll see, that's the same thread as E3D hotends, so you should be able to buy those instead. I found a batch you can buy in various sizes for just $11.75 over at Matter Hackers. However, I don't know if they will throw off the z probe height. I haven't tried them, myself so they may not work, but I might order a couple to test out...
-Kelly
ktfergus
Re: Ubis 13S tips
Postby Buchnerb » 2018-Feb-Sat-19-Feb
Thank you so much. I'll try some of theirs and I may try to make some out of brass. I guess I should get another 13S while they still have them.
Bruce
CNC Lathe Sherline
CNC Mill Sherline
Grizzly 11x26 lane
Rockwell Mill
Atlas Shaper
Buchnerb
Users browsing this forum: No registered users and 14 guests
