Probe stays lit
Probe stays lit
Postby AgentTDM » 2018-Jan-Thu-01-Jan
Had the new sensor that I used as a replacement working for a while...Only to wake up to find the new one with its light staying on as well even after it finished printing. My fear was confirmed when I saw it was no longer stopping/leveling like normal when I went to start a new print...Second probe that this has happened to. I have no idea what to do now, especially since even running new wiring and installing a new probe only made the problem go away for a while.
AgentTDM
Probe stays lit
Re: Probe stays lit
Postby RetireeJay » 2018-Jan-Thu-08-Jan
That does seem odd.
The probe senses nearby metal. Ideally, it would only sense metal "on-axis, in front" of the probe, but there's probably some sensitivity to metal that's off-axis but close to the front of the probe. So I'd suggest imagining that the probe is sitting on top of a slightly squishy ping-pong ball, and figure that any metal inside that ping-pong ball could trigger it. It will be more sensitive to steel than aluminum, but any metal can trigger it.
Re: Probe stays lit
Postby AgentTDM » 2018-Jan-Thu-08-Jan
The probe still does it even if I take it off of the mount and keep it away from metal. So, I'm not sure what the deal is. The red light is dim as well. I wonder if the z-stop section on the Printrboard is just starting to fail.
AgentTDM
Re: Probe stays lit
Postby RetireeJay » 2018-Jan-Thu-10-Jan
If you have the ability to temporarily jumper power to the probe (pins 2 & 3) but leave the "sense" lead (pin 1) disconnected, you could isolate the output signal of the probe from the input circuit on the board. Then you'd know for sure: if the probe stays "triggered" when connected only to power, then the probe is bad. If connecting the probe's output signal to the board is what forces it to appear "triggered" then there's a problem on the board.
Re: Probe stays lit
Postby AgentTDM » 2018-Jan-Thu-11-Jan
After doing an M119 command on the terminal, I saw that "z_min" was saying triggered when nothing is connected to the z-stop. Other times it would say "open when I connected something to it. I used a regular endstop to test that. I could only get it change from open to triggered a few times before it stopped.
AgentTDM
Re: Probe stays lit
Postby RetireeJay » 2018-Jan-Thu-11-Jan
AgentTDM wrote: "z_min" was saying triggered when nothing is connected to the z-stop
That's the correct behavior. If there's no electrical continuity between pin 1 and 3, then the board interprets that as "triggered". If there's a short between pin 1 and 3 (like an "endstop" switch that's not being touched) then M119 will report that as "open". Technically, it's actually an electrical closed circuit, but the switch is in the "open" or un-touched position.
Re: Probe stays lit
Postby Mooselake » 2018-Jan-Thu-12-Jan
It's a safety feature. CNC home and limit switches are predominantly "normally closed" so a broken wire is interpreted as a trigger and you'll fix the problem. Not as important in a lightweight 3D printer where a full throttle crash might pinch your finger a little, but extremely important if you're slinging a couple tons around and a crash could mean continued employment for a paramedic, plus a spare parts and billable time bonanza for the repair tech.
Printrbots, like virtually all 3D printers, only check these switches when homing. A missing or broken switch won't affect normal operation, just finding home (or the dreaded alien probing) when asked to do so with the appropriate gcode
Re: Probe stays lit
Postby AgentTDM » 2018-Jan-Thu-14-Jan
I
If there is a short in those pins, can the z-stop connector on the board be replaced?
AgentTDM
Re: Probe stays lit
I wonder also if this type of sensor contributed to the problem as well. It says 6v on its lowest side..And someone was telling me later on that the Printrbot only puts out 5v on that z-stop. Is that right? https://www.amazon.com/gp/product/B075F ... UTF8&psc=1
AgentTDM
Re: Probe stays lit
Postby RetireeJay » 2018-Jan-Thu-16-Jan
We need to know exactly which version of Printrboard you are using. There are slight differences from version to version regarding how they feed power to the probe and how they receive the signal from the probe.
That said, the probability of a failure of the connector itself is nearly zero. My reference to a short circuit or open circuit between the outer pins was in terms of experimentation you could do for troubleshooting.
Depending on the exact model of Printrboard, there are different possible scenarios regarding the transistor on the board that receives the sense signal, and the wiring that sends power to the probe. For example, in the schematic I showed earlier, you can provide the probe with a choice of either 12V or 5V for its power supply.
Re: Probe stays lit
Postby AgentTDM » 2018-Jan-Thu-22-Jan
RetireeJay wrote:We need to know exactly which version of Printrboard you are using. There are slight differences from version to version regarding how they feed power to the probe and how they receive the signal from the probe.
The one I'm using for the Simple Metal is the Printrboard Rev F4.
AgentTDM
Re: Probe stays lit
Postby RetireeJay » 2018-Jan-Fri-08-Jan
The schematic that I showed a few posts earlier is correct for the Rev F4. You have a jumper on the board that selects whether to power the probe with either 5V or 12V. If your probe is indeed one that can be powered from 6 to 36V, then your power selection jumper should be on the 12V (or HV) side.
At some point in the production of Rev F boards, they changed from using an FET (as is shown in the schematic) to using a bipolar transistor with built-in biasing resistors. That's because the FET is more fragile than the bipolar variety. There was no change in the layout of the board; each transistor fits in the exact same space. I say all this to say that it's possible for the FET to "burn out" without any visible damage. BUT if your board actually has an FET instead of the bipolar transistor, and IF the FET is burned out, then you would NEVER see any change of state using the M119 command, no matter what you did to the sense lead coming from the probe (or switch).
Not knowing the schematic of the probe, I can't say whether a burned-out FET could cause the probe's LED to come on continuously.
IF the problem is the FET, I can dig through my files and find the part number for the bipolar transistor. It would only cost you a couple of dollars to get from DigiKey. Then a shop that repairs cell phones should be able to replace the transistor on your board. Total cost would be much less than buying a new board.
But if you do decide to get a new board, don't get a Rev G unless you want a big adventure; they are totally different. Any of the Rev F boards would be physically and firmware compatible with what you have now.
Re: Probe stays lit
Postby AgentTDM » 2018-Jan-Tue-13-Jan
RetireeJay wrote:The schematic that I showed a few posts earlier is correct for the Rev F4. You have a jumper on the board that selects whether to power the probe with either 5V or 12V. If your probe is indeed one that can be powered from 6 to 36V, then your power selection jumper should be on the 12V (or HV) side.
The jumper is set to the "HV" side of the board. So, it may have just been that the sensor that I purchased as a replacement was faulty and just went out on its own. I have another sensor coming in a few days. So, I'll try that first, before doing anything else.
AgentTDM
Re: Probe stays lit
Postby AgentTDM » 2018-Jan-Wed-05-Jan
Just tried the new probe and wiring now. It's still not doing anything with the sensor problem. Even when I use the old wiring or new, nothing happens. There's not even a light showing anything is active in the sensor now. I'm afraid that that section on the board has just gone bad. Time to switch over to one of my spare RAMPS or other boards. That Printrboard in there right now is just showing that it can't do the job anymore.
AgentTDM
