headed bed fail seems to be board is fried
Postby werpknarly » 2017-Dec-Tue-20-Dec
new printerbot simple. was working well. now the bed will not heat. when i print or try to preheat bed the bed stays cold and a fail safe error shuts down printer when it detects the bed is not heating up. at the printerboard pins i get 2.5ohm resistance and when heat is called for i get 0.0 volts.. this is my 2nd printerbot, using repetitier .. could i have shut something off with repetier or slicer ???? should i return, or ??????????
werpknarly
Re: headed bed fail seems to be board is fried
Postby RetireeJay » 2017-Dec-Tue-21-Dec
I suggest going to this article https://printrbot.zendesk.com/hc/en-us/articles/115002295686-Printrboard-G2-Getting-Started-Guide and scroll down 2/3 of the way through the page to the second answer by Dave from the Printrbot team. Apparently there are some steps you need to take. I can't help you much because I don't have the Rev g board.
Postby Mooselake » 2017-Dec-Fri-11-Dec
Did you check to see if you had power at the Printrboard end of the bed wiring. It could be as simple as a missing connection or broken (check continuity) wire
