Printrbot Talk Forum • View topic - getting stuck (Resolved)
Postby mcdader » 2017-May-Sat-17-May
*** Cause and Solution **** Special thanks to this forum.
- Bootloader corrupt, AVR lock bits on, preventing firmware flash verification. Also Blank check fails.
- Bad Firmware causing printing issue. Too many different firmware's out there.
- Used Bus Pirate / avrdude to reset lock bits and reflash DFU bootloader.
- Re-flashed working firmware (RevF4-v1-SimpleMetal.hex attached zip file. After trying so many different firmware files, don't remember where this one came from)
Since this was a software issue, mods may move it to correct location. Thanks
I am working on gathering some other instructions and PIN layouts that I will attach to this post when they are done.
*** Original Posts Below ***
So I had to re-flash my boards firmware and now having odd issue. Board is F4 and used firmware simple-0.6.hex from Printrbots Github.
So while printing at random times during print getting a noise like motor is stuck and hotend keeps extruding in same spot. This only started happening after firmware update. I checked my M212 settings and same as before firmware flash.
Prints will complete if I keep retrying.
Belts look good and tension is good. Thinking I may have used wrong firmware, not sure.
Thanks for you help.
** Update ***
Went to reflash firmware again and now getting Blank Check failed. So sounds like board may be shot. :(
So flashed it with RevF_v5.hex, left blank check and verfiy unchecked and it seems like it flashed. Testing print now.
Making progress, Print finished, but part way through paused with loud buzz for 15-20 seconds then started up again.
mcdader
Re: getting stuck
Postby Mooselake » 2017-May-Sat-19-May
Which model Printrbot, and which controller board? The rev F is noticeably different then the previous boards, including using digipots to set the motor currents through firmware.
Re: getting stuck
Postby mcdader » 2017-May-Sat-20-May
mcdader
Re: getting stuck
Postby mcdader » 2017-May-Sat-22-May
Any Suggestions on which replacement printer board to purchase?
Certified Pre-owned Rev5 or Rev F6.
mcdader
Re: getting stuck
Postby Mooselake » 2017-May-Sun-08-May
I imagine you've checked for bad belt teeth, interference, loose cables, etc already. With the blank check fail you may have rotted away some program memory. Did it do an automatic verify? ( edit: see from the first post you didn't)
At $70 new the savings on a refurb can't be that much. I'd go with the bigger connector F6 (well, I'd probably try a rev G, but that way lies madness). You might need a bit if dremeling or filing if the cable opening isn't big enough. Through hole makes it a lot better attached to the board than the surface mount micro
Re: getting stuck
Postby mcdader » 2017-May-Sun-13-May
I was looking at the new G2, but it sounds like it is not working well yet. (heated bed and I would have to buy a new hot end.) Bigger usb connecter is definetly on my radar.
$30 difference between F5 and F6.
Going to research if there are any other brands as well.
It is not skipping, X,Y,Z are holding (on not moving) with load buzz. I tried manually moving them and cannot when it gets stuck. Only extruder continues to run.
I am going to order programmer and try and repair this board as well.
mcdader
Re: getting stuck
Postby mcdader » 2017-May-Wed-03-May
So I purchased a Bus Pirate and used it to re-flash the boot loader. I checked the lock bits and the were locked. Went ahead and flashed the CDC boot loader, then flashed firmware (both successful). Re-flashing the boot loader was a big learning curve. I am going to put together a guide from all the sites I used.
Issue still persists thought. Using RevF_v5.hex firmware. hmm, well enough for one night/morning.
-Found topic with same issue, Sounds like a firmware issue. Will try to track down other firmware versions. Plus didn't notice limits on CDC boot loader so going back to DFU.
viewtopic.php?f=29&t=10468&p=70258&hilit=simple+metal+stops+moving#p70258
mcdader
Re: getting stuck
Postby Mooselake » 2017-May-Wed-12-May
Do you like the Bus Pirate? I've looked at them, but too many irons, too many fires...
Try asking Printrbot, either via ticket or on the official forum, which firmware version they recommend for your bot. I see the Dozuki's been deactivated so no help there.
You can ask Plexus for access to the Wiki and post your guide there. RJ's is getting a bit dated.
After all this building your own firmware should be relatively easy. It's been covered here, both the Arduino and PlatformIO approaches. I'd suggest starting with the config file from PB's recommended firmware and go from there. There's been recent posts about the latest version of Marlin, perhaps one of the builders can share either their firmware (you'll need to, at least, reconfigure the EEPROM) or their config files. Do an M503, print the results, and fasten them in your Printrbot notebook for future reference.
Re: getting stuck
Postby mcdader » 2017-May-Wed-20-May
So real quick, Funny that you say ask Printrbot. I opened a ticket to see if they could point me to the Firmware. Reply was since my bot is out of warrant and no longer in production (Simple metal), They prioritize support for new customers, so I will not receive a reply.
Not sure I would recommend a Printrbot to anyone these days.
I have only used the Bus pirate for AVR programming so far, but I have looked a them in the past. I think it will come in handy for future tinkering. It was finicky to get working with avrdude
mcdader
Re: getting stuck
Postby RetireeJay » 2017-May-Wed-21-May
Re: getting stuck (Resolved)
Postby dinokale » 2018-Nov-Sun-22-Nov
mcdader can you post instructions and what you did? I have a printrbot and it is having communication issues with both mac and pc versions of cura, as well as other softwares ... changing serial modes does nothing .... it randomly starts working for about 10 minutes at a time once every 100029 tries. I would like to re-flash the firmware and have a buspirate but have never done something like this (I got a bus pirate a long time ago and never used it).
dinokale
It's funny all the current romanticism about printrbot (rip). Mechanically its such a beautiful simple little machine yet it seems many mistakes were made as a company and also in terms of support and designs.
I have recently come into possession of a printrbot simple metal and there are such basic avoidable design flaws such as no diagnostic indicator LEDs built in, USB and power cables hidden due to board placement, micro USB cable insert is loose due to board placement, micro sd card reader is recessed and micro sd card becomes stuck (I actually broke a 16gig card extracting it with tweezers yesterday), no built in heated bed, and very little information on the web, no on-off switch.
It's currently bricked 99.9% of the time and decides to work 0.01% of the time. Very little diagnostic information available to me. If I can't come up with a solution soon I'm going to have to purchase a smothie board or similar and retrofit this thing. This is a Rev F5 Printrboard.
dinokale
