Troubles with ExtrudrBoard
Postby elstak » 2017-Jan-Tue-06-Jan
Hi all,
First of all, sorry for my english. I hope will be enough to explain the trouble and solve it :ugeek:
I bought the board, I followed the instructions on reprap site to connect to RAMPS throughout aux2 port. The board is recognized and I can control the extruders.
Unfortunately, when I give the extrusion command the motor runs, it emits sounds but in fact unable to perform any step.
I have read several threads on this forum, but I can not solve the problem.
viewtopic.php?f=6&t=1975
viewtopic.php?f=15&t=4931
About the setting of Vref I followed the above thread about the mainboard but also with allegro driver. Having 1.33A motors I started from 0.8v (used in the discussion to provide 660mA to the engines, I increased slowly to the limit (1.6v to 1.32A, always following the istruction of the discussions above) but the motors, despite the zero load, do not move and seem to lose steps. To read the VREF I put the red on knob and black on a gnd of the EB.
I did not consider the setting of step (1/1 1/4 1/8 ect ..), I come from Pololu and is the first time I work with integrated drivers. How can I adjust?
There 's something I do not consider? The motors are connected with the pin 1 of the wire to the pin 1 of the board motor's connetor, it is indicated by a square instead of the circles as in this picture?
( however Also reversing the cable I get the same result, I have perhaps reversing only a few pins?)
Finding the same defect on E1 of ramps, after changing drivers I thought of a damage of the board, which is why I bought the extrudrborad. But now I have the same problem: the motors are not moving.
Any Idea?
Thanks
Francesco
elstak
Re: Troubles with ExtrudrBoard
Instruction for the ramps connection reprap o r g /wiki/Adding_more_extruders
elstak
Postby RetireeJay » 2017-Jan-Tue-10-Jan
Since you're getting sound from the motors but no action, I wonder if your motors are wired properly to the connectors. Stepper motors have two independent coils, and the standard wiring pattern where the motor connects to the board is for one coil to be connected to two pins on one end of the connector and the other coil to be connected to the two pins on the other end of the connector.
So if you unplug the motor from the board and check it with an ohmmeter at the connector, you should have low resistance between pins 1&2, low resistance between pins 3&4, and infinite resistance between any other combination of pins.
It's also possible to get noise out of a motor but no consistent motion if only one coil is being activated, but not the other coil.
Postby elstak » 2017-Jan-Tue-16-Jan
YEP!!!! :o :o :o :o :o
Thanks for the lesson about motor :)
I bought 4 wires from E3D online, the pin 2 and 3 are swapped on the board connector :shock: :shock: , i don't konw why.... fixed and now work... E3D.....E3D.... :roll: :roll:
elstak
