Printrboard Firmware Problem
Postby 4lathe » 2017-Jan-Wed-12-Jan
I posted the issue a few days ago on Hack Talk but perhaps it should be here. The printrbot forum doesn't seem that active anymore and I'm open to any help on where else I might post it. Thx much.
4lathe
Re: Printrboard Firmware Problem
Postby 4lathe » 2017-Jan-Mon-10-Jan
Just asking again. Does anyone know what board I could post a firmware question on. Thx
4lathe
Postby Mooselake » 2017-Jan-Mon-12-Jan
Software would be more appropriate, but don't worry about it too much. We look for unread posts, not in specific catagories. Subforums are, IMHO, important for historical use, I.e. has somebody else had this questions before. Topics that are in inappropriate areas can be moved.
Can't really tell where an unasked question fits, probably why nobody commented. What's your question?
Postby RetireeJay » 2017-Jan-Mon-13-Jan
Going back to your original post I see that you are trying to resurrect a bricked Printrboard by using an ISP programmer. There are very few people in this forum who have experience doing that, and perhaps none are actively looking at the forum these days (traffic here has slowed down a lot in the last 6 months). When you post a question but get no answer at all it probably means no one who read your post feels qualified to answer.
I had a Rev D board that went flaky (all on its own, not because I was trying to re-flash it), and I bought the ISP programmer and tried to use AVRDude to fix it, but I was not successful. I don't know for sure if my technique was wrong or if the board was truly unrecoverable, but I ended up getting a new Rev F board.
BTW, if you do decide to get a new board, I'd recommend the F6 over the G. I'm afraid that the G board will require the latest cloud-based software, which at last report is still pretty buggy.
Postby Mooselake » 2017-Jan-Mon-15-Jan
RetireeJay wrote:if you do decide to get a new board, I'd recommend the F6 over the G. I'm afraid that the G board will require the latest cloud-based software, which at last report is still pretty buggy.
While Brook has stated that the G2 based 32 bit new board will be usable in non-rain prone environments there's reports here that it hasn't happened yet. The new board is available in an experimenter's package, which seems to be a you break it you bought it product. Not even clear if it has a warranty, although I'd expect them to cover at least DOA boards.
The G2 is therefor for advanced users. Best to let it spend some more time in the oven unless you want to be one of the arrow backed pioneers.
Postby 4lathe » 2017-Jan-Tue-01-Jan
Thanks for the responses. I was concerned that perhaps no one had a solution for me. That's why I wondered if I should go to a forum like AVRfreaks or something. I have a new seemecnc max v3 that I've been fooling with but will order both boards for the printrbot to experiment with. I'm not going to give up on the RevF4 though. The board responds to programming completely normally so I think it's salvageable. I'll report any progress back here.
4lathe
Postby brookdrumm » 2018-Feb-Mon-19-Feb
The g2 board works for any printer ... you configure your equipment in the starting gcode. So it’s available if you want to try it out.
I realize it’s an old post... but I was looking around and decided tonrepond to g2 questions.
Usb printing is available as well as an optional (Limited) cloud software. I’ve run all my main printer models w the g2 - all sorts of configurations soninknownit works
Brook
brookdrumm
PBHQ Official
