Hot end temp swinging and bouncing
Postby Cre-ta Fab Lab » 2016-Nov-Mon-10-Nov
Hi,
I'm experiencing an erratic behaviour in the hot end temperature reading.
As you can see in the image attached during the heat-up - when the temperature rise constantly - the reading seems just fine.
When the target temperature (210°c) is reached the temperature reading become very unstable and swings between 190°c and 220°c in a very short time ( couple of seconds ), this is preventing the firmware to start printing.
I don't think the real hot end temperature can phisically change so fast so I suppose is the temp sensor failing, anyway I tried with the process of recalibrating PID parameters but the behavior remains the same.
Anybody experienced the same problem before? Any idea what to try next?
Any help is kindly appreciated.
Cre-ta Fab Lab
Re: Hot end temp swinging and bouncing
Postby RetireeJay » 2016-Nov-Mon-21-Nov
How long have you had the printer? Did it behave well in the past and just suddenly start exhibiting this problem? Did you make any changes, like substituting an E3D hot end for the original Ubis?
Check for loose connections in the thermistor circuit and especially check for wires that may be exhibiting fatigue failure - meaning the copper wires inside the insulation are broken and making erratic contact. You check for this by manually pushing, pulling, and bending the wires, particularly at points where they get repeatedly bent back and forth in operation. You can do this with the hot end at room temperature; if the readout is unstable you'll be able to see it. (In the future, prevent fatigue failure with "cable chain;" search for it.)
Another possibility is that the PID loop needs to be retuned. This has been discussed several times; search for it.
