Printrbot Simple Pro power problem
Postby foster » 2018-Oct-Mon-18-Oct
I’ve been trying to diagnose a problem with my printer and I’ve narrowed it down to a power problem.
I’m getting power into the machine, but the g2 board isn’t getting power.
I thought that the board was dead, and got a replacement board. When that didn’t work, but I tried plugging into the auxiliary power, near where the barrel port plugs in. Everything works if I plug into the auxiliary power! Which is great, but seems like I shouldn’t be relying on that.
Should I just plug I there? Or is that a bad idea (I suspect it is)?
Is this a problem that anyone else has run into that has a known fix?
I’ve been poking around with my multimeter and I can detect voltage at points near beginning of the power flow, but not where the power comes out to go to the g2 board.
Any ideas appreciated.
Thanks.
Sent from my iPhone using Tapatalk
foster
Re: Printrbot Simple Pro power problem
Postby musk » 2018-Oct-Tue-12-Oct
Inside the Pro there's a separate "powrboard" which is fuse-protected and only sends power to the G2 when a relay has been activated. When the LCD screen is connected, it closes a relay and then the powrboard sends power to the G2. There are two ways to bypass this. If you want to eliminate the LCD screen, there are a couple pins you can jump to make the relays automatically close. You could also just plug a 6-pin ATX cable directly into the G2 and ignore the powrboard completely.
Printrbot Metal Plus (2x)
Printrbot Simple Metal (2x)
musk
Postby foster » 2018-Oct-Wed-22-Oct
I don’t use the screen, so bypassing it would be fine. Do you know where to put the jumpers or where I can find the info?
foster
Postby novice » 2018-Oct-Thu-13-Oct
Watching this video https://www.youtube.com/watch?v=3B_ipknA8yo of Brook last week I could have swore he stated information regarding that jumper could be found on Carl's website https://ubishotends.com/simple-pro-information/, which seems to direct one to https://github.com/abdrumm/printrbot-docs. If it's in this pdf https://github.com/abdrumm/printrbot-docs/blob/master/G2-Board%20documentation.pdf ,I have yet to find it, but it's supposed to be there. Or is this not the same jumper?
Postby musk » 2018-Oct-Sat-16-Oct
Here's the cleanest way to jump.
Do yourself a favor and mark the black box with something permanent for future reference if the jumper ever comes off.
musk
