Home-All offsets [0,0,0] to near bed center!
Postby DickMS » 2015-Jun-Fri-12-Jun
Repetier-log (SMP-DH startup).log
Environment:
  • New Printrbot Metal Plus, never printed anything with it
  • Heated bed factory option newly installed
  • Dual extruder factory option newly installed
  • Dual extruder firmware newly flashed
  • Extruders leveled, per PB instructions
  • Bed sensor adjusted, per PB instructions
  • Repetier Host software being used, only for manual control so far
Problem replication:
Looking at the manual controls, there is an X-Y plane movement button-circle, that has individual home buttons outside it for (CW from upper left) X, Y, Z, and ALL.
After carriage is moved to random [X, Y, Z], press Home-All
Result:
  • Carriage executes a simultaneous Home-X and Home-Y (arriving at upper left of bed)
  • Carriage immediately moves to ~[90,127,current-Z] and begins to step down to Home-Z
  • Once Home-Z finishes, the DROs are all set to 0, with the carriage actually well into the build area, at [90,127,5]
Notes:
  • Operation was the same before the Dual-Extruder firmware was flashed.
  • Previously attached Prusa I3 went to its specified Home position when Home-All was clicked.
  • All three individual Home-?? buttons operate as expected, i.e. - no travel into the center of the build area.
  • Pressing the individual Home-?? buttons in the order X, Y, Z leaves the bed at [0,245,5], as expected.
Initial connection log, plus M501 outputs are attached.
How do I get rid of this placement error?
TIA!
DickMS
