As I was printing the printer stoped printing and then this came up.
event type: cir20r3
pg: sytem.object disposed exception
code: 0x0434f4d
Does anyone know anything about this or how to fix it?
Mooselake wrote:I'd also like to know what software you're using to control the printer. Afaik Printrun and Repetier-Host don't use .net, not sure if Cura does. It's pretty important to know what software generated the error, as there are many ways to communicate with your Printrbot.
orangefurball wrote:Mooselake wrote:I'd also like to know what software you're using to control the printer. Afaik Printrun and Repetier-Host don't use .net, not sure if Cura does. It's pretty important to know what software generated the error, as there are many ways to communicate with your Printrbot.
IIRC Cura doesn't use .net.
