Repetier-HOST V1.0.6 - g-code view?
Postby Cloneit3d » 2014-Dec-Sun-21-Dec
I have a Simple Metal and when I am in manual mode using repetier host v1.0.6 I cannot find where I can view the commands that I enter. I know using older versions of Repetier this was not a problem as it was obvious. Using Cura it is also right there to see after you enter a command. I have been looking at the Repetier forum and the manual however I cannot seem to figure it out. I am hopeful it is an embarrassing oversight but I am missing it. I am running Win8.1
Thank you-
CNC Plasma Cutter, own design
CNC Milling Machine
Printrbot Simple Metal with heated bed
2 other hopebuilt 3D printers
Cloneit3d
Re: Repetier-HOST V1.0.6 - g-code view?
Postby Cloneit3d » 2014-Dec-Sun-22-Dec
I got it - duh - toggle log - ok good laugh.
CNC Milling Machine
Cloneit3d
