Printrbot Talk Forum • View topic - Kisslicer setup for simple xl
Postby Munson » 2014-Mar-Thu-19-Mar
Can anyone give me a jump start and help out with setting up kid slicer for a printrbot simple Xl?
Munson
Re: Kisslicer setup for simple xl
Postby plexus » 2014-Mar-Thu-20-Mar
Specifically what parameters are you looking for?
Postby Munson » 2014-Mar-Fri-07-Mar
I just downloaded this and I am no familiar with it.I can't get a print off with the settings I have now.I was able to size the piece with the printer tab,selecting firmware and selecting 5D-absolute E.Also,I was able to enter in the x,y and z size for the printer.I am not sure what else I should change.When I dropped the g-code into repetier,the printer did not extrude during the print.So I tried a known g-code from another item and that printed fine.I would like to know what settings work well for others so I can try them.Thank you.
Munson
Postby Munson » 2014-Mar-Sat-14-Mar
I unchecked on de-string and I was able to extrude for anyone having the same issues.
Munson
Postby plexus » 2014-Mar-Sat-14-Mar
  • 2
Postby Munson » 2014-Mar-Sat-15-Mar
Plexus,thank you...but...but...but...how do I input that into kisslicer? I would love to give it a try,Not sure how to?
Munson
I originally was looking at the settings tabs on kisslicer(what to change),But if what you put up supersede's that then I'll use it.That is one grade level up from me right now...
Munson
Postby plexus » 2014-Mar-Sat-15-Mar
Postby Munson » 2014-Mar-Mon-17-Mar
Thank you for all of your help Plexus.I would like to ask you one thing,The files you sent me.....What tab do click on to drop the codes? Matl-gcode,printer?ptr g-code?
Munson
Postby plexus » 2014-Mar-Mon-23-Mar
That code is from the .ini files indicated. im not sure what the filenames you are referring to are.
Postby sheriftaher » 2014-Apr-Wed-03-Apr
Hello Everybody,
thanks plexus, your code was helpful for setting my printrbot simple on kisslicer, i have a problem and wonder if anyone faced it
I'm using kisslicer 1.1.0 and for some reason I can't control the speed at which the object is printed
I tried changing the speed in printer settings several times but the feed rate that comes out in the gcode is still the same, I also tried playing with the speed slider to extremes but now difference
anyone faced that before ?
sheriftaher
Postby plexus » 2014-Apr-Wed-11-Apr
Postby sheriftaher » 2014-Apr-Wed-13-Apr
Thanks plexus :D
I tried changing the slider to the absurd rate (1mm/s & 2mm/s) but the gcode always comes out at different rates regardless of what the slider has
I reset the Ptr G-code pre and post to defaults (which are really nothing other than home and set units to mm commands)
the gcode is very large so I've attached the first 2500 lines only, you can see that feed rates are in the order of 70mm/s (F4200) and more in some cases
:( still don't understand why the rates are coming out fixed (btw, I tried this on windows and linux machines, exact same behavior)
spiral.send.gcode
sheriftaher
Postby Munson » 2014-May-Thu-16-May
Plexus,Where is the reputation system in here?I use tap talk
Munson
