Printrbot Talk Forum • View topic - 9 point auto leveling not working
Postby RPearce » 2016-Jul-Sun-13-Jul
Hey lads, i cant figure out marlin for the life of me, but i have the Flip process down pretty good, anyways ive been running a good file on my PB SM W/ H and the file is for an E3D head, plus 9 point level. it works great! now i have a play and a plus that both just got E3D Heads, i flashed the same firmware into them and now both wont move the beds, they just bounce along the gantry 9 times with out moving the bed. if anyone has any ideas? or wants to review my firmware file let me know and ill share a drop box link. could someone here by chance compile the proper Hex file for the play and plus for me please?
Ryan Pearce, CEO Pearce Industries
www.PearcePlastics.ca/
Printrbot Play - Heated bed + E3D V6
Printrbot Simple Metal - Heated Bed + E3D V6
Printbot Plus + E3D V6
RPearce
Re: 9 point auto leveling not working
Postby RetireeJay » 2016-Jul-Sun-15-Jul
Hi Rpearce,
All of us who are active users of this forum saw your first post because we use the feature to "see recent posts" - and new posts that we haven't looked yet at are highlighted with a red icon. So multiple postings on the same topic in different sub-forums don't increase your chances of getting an answer.
There are some on the forum who seem to like 9-point bed tramming (aka "leveling") but there are many of us who think it's a waste of time. The reason is this: "bed leveling" software ONLY calculates a correction for a flat, plane surface that's not exactly perpendicular to the X and Y axes. Mathematically, three points are sufficient to define this plane. The mechanical precision of the actuators is good enough to make this mathematical calculation as accurate as it needs to be.
If your bed is not truly planar (i.e. it's warped) then the 9-point leveling will possibly do a better job of finding the average or "best fit" plane, but it won't correct for the warping itself.
So here's my personal opinion:
- I'm convinced that the very best way to print is on a surface that is planar and is mechanically adjusted to be parallel to the plane defined by the X and Y axes, no probing or software corrections needed.
- The second-best way to print is on a surface that is planar and nearly parallel to the X-Y plane, adjusted (fine-tuned) in software by 3-point leveling.
- And if you have a surface that is so warped and non-planar that 9-point leveling makes a serious difference in the calculation of the corrected plane, then you will still have problems with your prints because the nozzle is never a consistent distance away from your bed.
Finally, to directly answer your question, I don't have (or want) a probe; I don't do software bed leveling, so I can't help you to do what you want to do. Sorry. But maybe someone else can and will; we have dozens of active contributors to this forum.
Looking again at your question: do all three printers have the Y axis "home" switch in the same place (either at Y=0 or Y= Max)? If, for example, your Simple homes to Y = Max but the other printers have home at Y=0, then this might explain your behavior.
Anyway, do an M503 to see what each printer is using for bed size and other parameters (I don't know exactly what parameters you will see on your version of the firmware). Perhaps by studying the parameters there you can figure out what needs to be changed. These parameters are stored in EEPROM and you can change them yourself without re-compiling Marlin. See the sticky post in Software - Newbie Talk about EEPROM settings. You almost certainly want to change your bed size for the bigger printers.
Postby RPearce » 2016-Jul-Sun-17-Jul
yes sorry for the double post, i wasnt getting any bites, so far im doing better here, unfortunatly, i have adjusted all there units firmware so i no longer know what the OEM position is, that being said, the play is running its oem firmware again if im not mistaken. i have all three units open right now,
Play > M503
< echo:Steps per unit:
< echo: M92 X80.00 Y80.00 Z2020.00 E96.00
< echo: M203 X125.00 Y125.00 Z5.00 E14.00
< echo:Home offset (mm):
< echo:PID settings:
< echo:Min position (mm):
< echo:Max position (mm):
< echo: M211 X100.00 Y203.00 Z130.00
< echo:Bed probe offset (mm):
< echo: M212 X0.00 Y0.00 Z-1.50
Simple > M503
< echo: M92 X80.00 Y80.00 Z2020.00 E93.50
< echo: M211 X152.40 Y152.40 Z152.40
< echo: M212 X0.00 Y0.00 Z-0.15
and the Plus > M503
< echo: M203 X100.00 Y100.00 Z100.00 E14.00
< echo: M211 X254.00 Y254.00 Z254.00
< echo: M212 X0.00 Y0.00 Z5.00
i honestly have no idea what im doing in regards to coding a machine, i will review the suggested literature. i put marline.cpp.hex into the plus and it just hates it. but the OEM firmware was being weird and wouldnt talk back to the computer so im kinda stuck. i just prefer the 9 point level over the 3 and IMO its a preference thing. i my play using the 3 my simple use the 9, i just prefer the 9 over the 3. as for changing the settings my self, i am not sure what they need to be to accommodate the E3D heads, and i cant find there source code for marlin, and Git is a nightmare to try and use. thank you guys for working with me so far, hopefully we can figure it out today.
RPearce
i have reviewed the suggest article viewtopic.php?f=18&t=2763 it does not make any sense to me, i write to my machines from Cura using pronterface UI, nothing in that article seemed relevant? unless im supposed to be viewing the information they are talking about inside marlin.
RPearce
Postby RetireeJay » 2016-Jul-Sun-17-Jul
Postby RPearce » 2016-Jul-Sun-18-Jul
RPearce
Postby Mooselake » 2016-Jul-Sun-20-Jul
You should be able to download the official firmware from Printrbot's site. For the source (it's a modified Marlin) look on . I didn't poke around, but it was recently updated so the odds are good it's the source Printrbot used.
I echo Jay's comment on 9 point leveling. Like many urban myths that one has propagated far beyond what it should have. Supposedly if your bed is really out of whack (likely by whacking it too hard) it might make a small difference by helping to average the tilt over more points, but if you need that then you're at the point you need to do some serious repairs. The probe's accuracy is less than the Z step size (another way of saying that is that the probe will trigger at different points that are more than a step apart) so all that extra probing doesn't actually add anything.
If you enjoy firmware building and updating for the fun of it go ahead, but if you're expecting better results spend you time finding out what it takes to actually make that printing surface the same distance from the print head all over (aka the mislabeled bed leveling). Like Jay I have a plywood bot that's nowhere as rigid as the metal ones, but have the bed "leveled" within the 1/100" of a mm resolution of my dial gauge. This probe stuff is to reduce manufacturing cost and tolerance, not because it provides some secret sauce.
Postby RPearce » 2016-Jul-Sun-20-Jul
so i guess out of the 8 hex i downloaded i found one that works, now new problem, the probe is off set from the head, so much so that when it would inspect at 244 the probe misses the bed, is there any way to have it inspect at say X (or Y?) 230
here is my results from the inspection
< Bed x: 10 y: 10 z: -5.03
< Bed x: 127 y: 10 z: -6.23
< Bed x: 244 y: 10 z: -11.00
< Bed x: 244 y: 127 z: -11.00
< Bed x: 127 y: 127 z: -6.93
< Bed x: 10 y: 127 z: -5.25
< Bed x: 10 y: 244 z: -5.27
< Bed x: 127 y: 244 z: -6.95
< Bed x: 244 y: 244 z: -11.00
RPearce
the hex im using i dont think i can use, im getting a perfect rhythm from my print head from it, 265 to 275 then back down over the course of 10 seconds over and over. so i think something is wrong in it, other files would hold a steady temp, so idk. ive got like 3 files left to try and then im stuck. and the OEM Hex from printrbot simply doesnt work with this machine. it just gets stuck on opening serial port.
RPearce
Postby RetireeJay » 2016-Jul-Sun-21-Jul
Postby RPearce » 2016-Jul-Sun-21-Jul
ok so for giggles, and since it was the only Hex i had left, i told my Plus that is it is a Play, its programmed as a play, but i increased its bed size to that of the Plus, and its actually working with the E3D head just fine, 3 point level like the play but otherwise its all working. its even printing at 270c with out a problem so i guess my machines are good to go, i dont think anyone here is going to compile a 9 point for me and these are working so i guess im fully operational.
RPearce
Postby RetireeJay » 2016-Jul-Mon-13-Jul
Glad to hear that you are up and running!
One issue that we didn't discuss but might explain SOME of your difficulties is that there are two incompatible versions of the Printrboard in common use. Printrbot printers made in the last year or so ship with a version of the Rev F board. But older printers and probably most clones ship with Rev D boards. I know from personal experience that Rev D firmware won't work correctly on a Rev F board, and vice versa. So if you loaded a hex that was compiled for a Rev D board onto a Rev F board, then yes, it's going to be unhappy. There are enough similarities that it may seem to work partially, but there are a couple of differences to prevent full functionality. If you want more details, you can look at this post: viewtopic.php?f=21&t=10715&p=69152
