using acrylic mounted on top of bed
Postby hmerzin » 2016-Jan-Fri-12-Jan
I've been trying to print with acrylic for platform adhesion for PLA. I can't seem to find the GCODE for preventing the head for going all the way down to the bed instead of stopping at the surface of the acrylic. I tried to set the M212 Z offset to the thickness of the acrylic but it only gouges the acrylic and digs in.. Any suggestions??
hmerzin
Re: using acrylic mounted on top of bed
Postby ChefScott » 2016-Jan-Fri-12-Jan
The probe can not sense the metal bed underneath the acrylic (IIRC it only has about a 3 or 4mm range). To work around that you could place some aluminum tape where the probe "looks" for the metal bed.
ChefScott
