Test cube Z height question
Postby bbrown64 » 2015-Aug-Mon-09-Aug
I had to print the test cube PB offers. It is 20x20x3. However when I printed the cube this morning my test print was 20x20x2.5. I would really like to have exact right height. I checked the EEPROM it is X80 Y80 Z2020 E96. My layer height is .2064, Btm and top layers are .6. There are 14 layers to the test cube. How do i gain that .5mm in height?
Bill Brown
Tulsa, OK
bbrown64
Re: Test cube Z height question
Postby RetireeJay » 2015-Aug-Mon-10-Aug
It's your Z calibration value that needs to be fixed. It depends on the exact type of Z actuator screw you have. There are on-line calculators for this, once you know the type of screw.
Postby bbrown64 » 2015-Aug-Tue-04-Aug
Thank you Jay I made the correction to my EEPROM. Now my cube is right on the money. ;)
Bill Brown
Tulsa, OK
bbrown64
