A Good Profile
A Good Profile
Postby bbrown64 » 2015-Jul-Thu-08-Jul
I want to share a good profile that works for PLA. Currently I am using white PLA. However this same profile works well with Blue as well. I have not tried it with any other color or product.
Bill Brown
Tulsa, OK
bbrown64
A Good Profile
Re: A Good Profile
Postby Mooselake » 2015-Jul-Mon-08-Jul
I'd add the usual caution - every printer and every spool of plastic is unique and will be different. Someone else's profile can be a good starting point (not to mention an excellent example), but you'll still need to check and possibly adjust speeds, use your measured filament diameters, temps, possibly bed dimensions, etc.
What model and vintage Printrbot is this for?
Re: A Good Profile
Postby bbrown64 » 2015-Jul-Tue-17-Jul
The printer I use is PB SM model 1403.
Bill Brown
Tulsa, OK
bbrown64
Re: A Good Profile
Postby Mooselake » 2015-Jul-Tue-20-Jul
I should have asked which version of Cura, since there is a bit of an issue with Cura 15 not including PB config files, and your ini file might help somebody out.
Re: A Good Profile
Postby bbrown64 » 2015-Jul-Mon-08-Jul
I am using the most current version of Cura. It did have the PB Simple Metal profile to choose.
Bill Brown
Tulsa, OK
bbrown64
