by RetireeJay » 2015-Jun-Mon-06-Jun
It's kinda yes and no. I have often experimented with settings, for example to get the walls to fill in just right or get the support to do what I want it to do. So the ability to save the G-code and give it its own descriptive name is helpful. On the other hand, the G-code has been generated with a specific filament diameter (and optimum extrusion temperature), and it won't be as useful for doing a print at a later date if you are using a different spool of filament.
For those who are using Repetier instead of Cura (including myself), I strongly prefer to generate a G-code file with Slic3r and then load the G-code into Repetier - because I get more (or easier) control over the slicing process that way. That's not an issue with Cura because Cura is first and foremost a slicer with in-depth controls, and only incidentally a User Interface to the machine.
