Is inductive sensor required?
Postby DonaldJ » 2015-Mar-Sat-13-Mar
I'm not a fan of automatic bed leveling. If I got a Metal Simple, could I disconnect and remove the sensor?
DonaldJ
Re: Is inductive sensor required?
Postby RetireeJay » 2015-Mar-Sat-15-Mar
I would say yes you could remove the sensor. Of course you won't be able to use the G29 command. But you still need a way to adjust your Z clearance. On a Simple, I guess you can do it by hand if you put a knob on top of the Z threaded rod. The firmware assumes that wherever it is when it turns on is 0, 0, 0. So if you manually adjust every time you turn it on, you should be OK. That's what the first Simples did before they added switches.
There probably won't be a place on your machine pre-designated to install a mechanical Z switch, nor a way to adjust the trip point of said switch. But if you can design a way to install a switch, you'll find it more convenient than manually zeroing. Unfortunately, the Simple Metal is not as friendly for user hacking as the wooden version; but it can be done.
Postby DonaldJ » 2015-Mar-Sat-15-Mar
RetireeJay wrote:There probably won't be a place on your machine pre-designated to install a mechanical Z switch, nor a way to adjust the trip point of said switch. But if you can design a way to install a switch, you'll find it more convenient than manually zeroing. Unfortunately, the Simple Metal is not as friendly for user hacking as the wooden version; but it can be done.
Hmm...no Z endstop, eh? I didn't consider that, but it's not a deal breaker. Is there a connector on the new Rev.F Printrboards for such a switch?
DonaldJ
Postby teicher » 2015-Mar-Sat-16-Mar
I would recommend that you still go through the Z offset calibration steps for the probe and get it working, then simply remove G29 from your starter gcode.
teicher
Postby orangefurball » 2015-Mar-Sat-16-Mar
If you just remove the G29 Gcode you can just use the inductive probe as an endstop. Of course if the probe is broken then a design add on will be required.
Thingybot Delta Printer
http://www.thingybot3d.com
orangefurball
Laser scintillater
Postby RetireeJay » 2015-Mar-Sat-17-Mar
DonaldJ wrote:Hmm...no Z endstop, eh? I didn't consider that, but it's not a deal breaker. Is there a connector on the new Rev.F Printrboards for such a switch?
Yes, it's the same connector. On a Rev D board, you just plug in the switch (the probe gets its power separately). If you have a Rev F board, probe power comes through this connector and you need to move a jumper to enable the mechanical switch instead. Google Printrboard Rev F.
Postby DonaldJ » 2015-Mar-Sat-17-Mar
RetireeJay wrote:Yes, it's the same connector. On a Rev D board, you just plug in the switch (the probe gets its power separately). If you have a Rev F board, probe power comes through this connector and you need to move a jumper to enable the mechanical switch instead. Google Printrboard Rev F.
That will work. The plan is to have the heated bed and a removable glass plate, similar to what I have on my PB+. Using the probe as an endstop might be problematic with the glass bed.
Thanks!
DonaldJ
Postby teicher » 2015-Mar-Sat-21-Mar
Ah, if you're going to use a glass plate, I agree with the you on not using the probe and favoring a mechanical switch.
teicher
Postby Sagbot » 2016-May-Mon-21-May
I run with no auto level and no z limit switch. I removed all Z homing from the Start G-code.
After turning the bot on and heating up the hotend, I turn the screw to position the tip near the surface. I still use a piece of paper and try to get it close.
Then I execute G92 Z0 to zero the Z axis.
*** This is a bit dangerous because if you forget to run G92 Z0 after lowering the head yourself, the head will plunge into the surface.
When the print starts, I adjust the screw by less than 1/8 turn (that's 45 degrees) as it prints the perimeter. 1/8 turn is about 0.1 mm.
The whole process takes 15 seconds, and once the calibration is made, it's good until you turn the bot off. Print after print works. You can always leave the bot on overnight if you don't enjoy the manual calibration routine.
At this point I don't want to install a limit switch for Z, because RetireeJay and others have had significant difficulty setting one up with sufficient precision.
I'm printing PLA on a polycarbonate slab and use a 3 point bed levelling scheme.
-Mike
-Mike
Printrbot Metal Simple, Meanwell power supply, polycarbonate sheet.
Sagbot
