Fan Question
Fan Question
Postby donde » 2014-Jul-Fri-21-Jul
I have the Simple 2014 with Upgrade Kit. The Hex file I'm using is Marlin.Simple.Inductive.V3.hex
This combination has been up about a week and prints fine. However, I now notice the fan doesn't start till about 2 layers before the
the end of the print. And it runs at 100%. speed. I don't think this is right. Before the Update I used the default Hex file of the Simple.
The fan would be off for a few layers and then come on at low percentage and then go faster as the print progressed. This seemed correct.
And near the end of the print it would be at 100%.
donde
Fan Question
Re: Fan Question
Postby Defy » 2014-Jul-Sat-08-Jul
Weird i wouldn't think that was a firmware thing. Maybe some other folks will chime in.
I have mine worked out were basically i run both of my fans at 80 percent all the time for pla and for abs i only run the extruder fan.
I am running the simple metal hex's on all my bots
Defy
Re: Fan Question
Postby donde » 2014-Jul-Sat-08-Jul
I see, so you don't use auto cooling in slic3r at all. And set the fan speed manually. Why is that? I guess maybe for ABS.
I thought most use auto cooling. Where is your other fan mounted? I have just one through a shroud pointing at the bed.
Do you have a bed heater?
donde
Re: Fan Question
Postby Defy » 2014-Jul-Sat-13-Jul
I dont know if its better to use the auto cooling or not but the 80% trick on pla works for me ymmv.
I have a heat bed on one of my bots but i only use that for abs. Haven't found the right pla printing temps to get good results on a heat bed. Painters tape and aquanet works great for me.
I have the other fan on the extruder because i was getting alot of clogging and jams.
Defy
Re: Fan Question
Postby AmazingSpanoMan » 2014-Jul-Thu-11-Jul
Defy, Which Heat plate are you using on the 1405 simple? I'm assuming that's the extended aluminum plate you can buy off of the Printrbot store with longer belt and rods. Do you have it plugged in to the printrboard or are you running power to it a different way?
AmazingSpanoMan
