Sensor Wrench
Sensor Wrench
Postby donde » 2014-Jul-Sun-16-Jul
The top nut is harder to get at than the bottom nut. Instead printing a new one, Just sawed a notch is the right side of one of the wrenches.
With the PB logo showing, looking at the right side of the wrench, measure about 18mm from top edge of the wrench. This is where you will start to cut a
rectangular notch. Slice down 10mm. Measure again from top edge of wrench, this time, mark at 35m from top edge of wrench, Slice down another 10mm.
Remove this piece of wood. I use a small hobby hack saw, a small flat file, sandpaper, etc. Put wrench in a vice to make job easier. Mark the wrench Top Nut. The bottom nut doesn't have the same clearance problem as the top, so the other wrench can be used there. Now the modified wrench will get to that flat of the top nut you couldn't get to before. Come on PB, make a better top nut wrench! :D
donde
Sensor Wrench
