Z Probe + Heated Bed problems
Postby Dudemeister » 2014-Jul-Wed-02-Jul
I have been struggling for the past few hour trying to get the Z Probe dialed in.
First, the original probe included with the PB dies, then I got a replacement, but this one was a xxx/BX mode instead of xxx/BY. The difference between them is the BX logic is reversed. No probelm, I adjusted the firmware to fix that.
My problem are 2 fold. First of all, I can't seem to be able to tweak the probe adjustment using the M212 Zxx command. I know the setting is stored because I can issue a M501 command and I can see the setting I just entered. Problem is that no matter what value I enter in there, the probe doesn't change physical height.
The second problem is that the probe seem to be affected by heat. I have a heater bed, and once I have the bed a 90°, the probe triggers permanently, so it's no longer of any use.
Has anyone else encounter similar problems?
Solidoodle 3 w/mods
PrintrBot Simple Beta with too many mods
PB Maker Edition w/Heated bed
Dudemeister
