Printrbot Talk Forum • View topic - Massive slipping or software issue, or something else?
Postby seoushi » 2014-Jan-Wed-23-Jan
It seems that my printer is slipping very badly or my software is doing something weird. I'm trying to print but every few layers it shifts 5-8mm or so in the Y direction. I've tightened the Y axis and still can't figure it out.
Here are some images of the print and some of my printer settings.
http://imgur.com/a/eD15M
I'm using repetier-host 85b which has slic3r 0.9.9 (later versions or repetier can't even send commands to the printer, would be nice to find out why this is as well but it seems to be a software bug that quite a few people have).
seoushi
Re: Massive slipping or software issue, or something else?
Postby thawkins » 2014-Jan-Thu-01-Jan
Postby ivymike1031 » 2014-Jan-Thu-09-Jan
my printerbot had printed fine for a long time and then it started skipping in the y direction ... turned out it was because one of the linear bearings was going bad and sticking occasionally. I haven't replaced the bearing yet, I just oil the heck out of it each time I start a print, and it makes popping noises until the print is done.
ivymike1031
Layer 100 of 1234
Postby RetireeJay » 2014-Jan-Thu-10-Jan
Postby ivymike1031 » 2014-Jan-Thu-11-Jan
"constrained" at three points four points, I think, since there are two linear bearings on each rod (PB+)
once upon a time it moved smoothly without noises ... but now there is a particular bearing (out of the 4) that makes lots of noise and sticks occasionally. The forces can't be very big, as the rod mounts on the bottom of the bed are pretty compliant and if the bed is extended to the end of travel it can be rocked back and forth easily by hand (maybe 6mm of x travel at the back end of the bed).
Aligning the two rods so that they are parallel within microns (as suggested) will be virtually impossible given the mounting arrangement of bearings sitting in rectangular holes cut into a piece of wood, wouldn't you agree?
ivymike1031
Layer 100 of 1234
Postby seoushi » 2014-Jan-Thu-21-Jan
So I figured out the issue. my bed size was set slightly too large in the y direction so it would move back further than it should causing the issue above. I made another print and now I'm getting the dreaded slant, think it's just a matter of leveling my bed better and putting a few more loops around the y axis.
seoushi
Postby thawkins » 2014-Jan-Thu-21-Jan
Postby seoushi » 2014-Jan-Fri-00-Jan
Thanks for that. I was able to print out the calibration cubes without an issue with slant now. The last real issue I have is on the Z axis, it seems to be uneven when going up. Around 25-30mm it doesn't step up as much so it squishes the print. The other issue I have is my y only extends out to 75mm instead of the full ~100mm, this is due to the zip tie catching on the wood base.
so I can't print what I want to (3DR printer)
seoushi
Postby seoushi » 2014-Jan-Sat-03-Jan
fixed it.
seoushi
Users browsing this forum: Bing [Bot] and 2 guests
