Printrbot Talk Forum • View topic - Jon Lawerence's X & Y GT2 belt mod
Postby ahaer » 2013-Dec-Fri-07-Dec
- 160mm Z axis (thing:215625)
- 190mm metal bed
- 160mm z travel
- 1U PC Power supply
ahaer
Re: Jon Lawerence's X & Y GT2 belt mod
- 190mm metal bed
- 160mm z travel
ahaer
Here is a picture of the installed y-belt mod.
The only modification I made to the existing wood was to cut this notch. Using this notch I was able to put and the bearing on AFTER the y-axis was re-installed and tighten the set screw by inserting a normal allen key at a ~30 degree angle. Given the large flange on the GT2 gear from PrintrBot it is NOT possible to install the bearings after the gear because they overlap soo much. This would mean if I installed the GT2 and bearings before the re-installing the y-axis the clearance hole would have had to be big enough for the GT2 PLUS BOTH bearings..
- 190mm metal bed
- 160mm z travel
ahaer
Postby ahaer » 2013-Dec-Fri-08-Dec
Here is a picture of the X-axis mod installed:
One very important point if you try this mod - your printer must be calibrated for you to have any hope of the main part fitting! I think my z-axis was a little "long" so I had to spend a while filing the tabs to get the part to fit with the wood parts.
A undocumented modification to a wood part is required to make this work. With the printrbot GT2 gear the large flange (17.75) mm would rub against the bottom. I had previously cut out this hole so that I could see the motor shaft shaft from the bottom. You may need to do the same. IMHO this is worthwhile thing to do in any case so that you can see what is going on.
There is one problem with this modification as it currently stands: There is a significant reduction in y travel (30mm) when the belt support pieces hit the bearings. Note the amount of unused rod to the left of the bearings
Even if the belt support didn't extend beyond the wood tabs there would still be a lot of unused travel. I'm sure that it is because the 608 bears are much larger diameter than what was used in the original MXL version
The fix for this problem is to rotate the y-axis rod plate 180 degrees so that the tabs are in front and make new belt support tabs. In this configuration the plate AND the bed move forward enough that the bed doesn't have to be raised over the bearings. This means less wobble and less new parts required! Now that I've got things back together I'll work new x-belt supports
- 190mm metal bed
- 160mm z travel
ahaer
Another note - to make the Y-axis limit switch work properly I had to move the screw that trips the switch 15mm to the right. You can see this in the "X mod installed" photo of the previous post...
- 190mm metal bed
- 160mm z travel
ahaer
Postby Jon Lawrence » 2013-Dec-Fri-10-Dec
Jon Lawrence
Calibration mode.
Postby ahaer » 2013-Dec-Fri-11-Dec
- 190mm metal bed
- 160mm z travel
ahaer
- 190mm metal bed
- 160mm z travel
ahaer
BTW - the bearing caps for the X-axis mod seem plenty thick/strong too me.
- 190mm metal bed
- 160mm z travel
ahaer
Postby Jon Lawrence » 2013-Dec-Fri-12-Dec
Jon Lawrence
Calibration mode.
Postby Jon Lawrence » 2013-Dec-Fri-13-Dec
Jon Lawrence
Calibration mode.
Postby ahaer » 2013-Dec-Fri-13-Dec
- 190mm metal bed
- 160mm z travel
ahaer
Postby Jon Lawrence » 2013-Dec-Fri-14-Dec
I hear you. Solidworks is fantastic, but the cost is outrageous for a legal license. Fortunately, I have it for my day job and get to play at night...
Jon Lawrence
Calibration mode.
Postby Jon Lawrence » 2013-Dec-Mon-16-Dec
I updated the Motor plate and tie bar for the Y axis (http://www.thingiverse.com/thing:194586). Shortened the pilots for the bearing mounts on the motor side and added pilots for the bearings on the tie bar to allow bearings to be removed with pulley in place.
I also added a notch in the motor plate to allow wrench access to the belt pulley. Hopefully a ball end allen wrench will get in there. Please let me know if this eliminates the need to cut the wood.
The X changes will take a little longer, and I will have to find some free time. I will post when they are done.
Thanks again for the feedback.
Jon Lawrence
Calibration mode.
Postby Jon Lawrence » 2013-Dec-Tue-16-Dec
OK, The next iteration of the X-GT2 belt is avaialable: http://www.thingiverse.com/thing:194686
Thank you for helping debug the GT2 design. Any and all feedback is greatly appreciated.
Jon Lawrence
Calibration mode.
Postby ahaer » 2013-Dec-Wed-08-Dec
- 190mm metal bed
- 160mm z travel
ahaer
Postby Jon Lawrence » 2013-Dec-Wed-09-Dec
Jon Lawrence
Calibration mode.
Postby ahaer » 2013-Dec-Wed-14-Dec
Excellent! I will print and install the new parts tonight!
Thanks again!
- 190mm metal bed
- 160mm z travel
ahaer
Postby ahaer » 2013-Dec-Thu-08-Dec
Rev A is an improvement over the original but it still restricts the total x-axis movement to 86mm because the part projects into the bearing clearance slot
My solution to this problem was to simply cut off the part so that it ends at the start of the slot opening. With the tie-wraps tightened the assembly is plenty solid.
One thing that I did run into was that the tie wrap head wound up taking up most of the space between the carrier and the bed. My solution to this was to widen out the tie-wrap clearance hole so that I could rotate the tie-wrap end down into the carrier plate so that it did stick up any further than the tie-wrap itself
Other installation notes
- install the bearing carrier so that the tabs face forward. Its a easier to do the new x-axis stop if you flip it so the endstop screw hole stays on the left rather than rotating it 180 degrees like I did in pics above
- install the bed in its normal position (ie so that the narrow gap between screw hole and edge is at the front). If you reverse the bed too the y-axis home position will be off the bed by a couple of mm
- drill new axis using same X coordinate as original hole and a y that works with clearance slot on the left side piece (basically how its shown on the PDF file)
- I used two tension blocks but only put screws in one of them. I just realized that the endstop itself has a belt holding groove too and will try making with only on tension block and screws later
I printed a quick part and everything work properly. Next up I'll look into speed settings...
- 190mm metal bed
- 160mm z travel
ahaer
Postby Jon Lawrence » 2013-Dec-Thu-09-Dec
Parts updated and Rev B uploaded. I should have caught the travel issue, my apologies to you and your X carriage that ended up under the saw...
Thanks for all your assistance ahaer!
Jon Lawrence
Calibration mode.
Postby ahaer » 2013-Dec-Sun-18-Dec
I've made a new thing based on your parts that increases X printer width to 185mm
see viewtopic.php?f=106&t=5914
- 190mm metal bed
- 160mm z travel
ahaer
Postby Jon Lawrence » 2014-Jan-Mon-10-Jan
Jon Lawrence
Calibration mode.
Postby djsloanau » 2014-Jan-Mon-22-Jan
Ok folks, after seeing this post and the previous one, it has decided my purchase for the Printrbot Simple. I was tossing up between the simple and the Jr, but I don't like the layout of the Jr, I think the simple's structure is more sound, except for the x y fishing line. With the success you guys have had putting in GT2 belts, and extending the print volume, the Simple becomes a force to be reckoned with in the printer world.
Is there any reason why you have used the 608Z bearings rather than the slightly smaller 624ZZ?
Thanks for all the great designs and the detailed drawings and parts info. I can't wait to get started and I haven't even placed my order yet. I can get all the parts locally for buttons, between AUD$1.50 and AUD$5.20 each for the belt, drive gear and bearings.
New to the 3D printing game, but not to 3D design
Printrbot Jr V2 with Aluminium extruder
Mods
Y axis tensioner thingiverse thing:143410
Feet to stop vibrations thingiverse thing:212515
extra fans on extruder motor and alimunium head thingiverse thing:274200
hot plate adjustment thumb screws (front only) thingiverse thing:66096
djsloanau
Postby thawkins » 2014-Jan-Tue-04-Jan
Postby Some Printr Noob » 2014-Feb-Sat-23-Feb
Well, I don't know how to comment on thingiverse, so I'll comment here instead.
My Y-Axis fishing line broke after 2 weeks of printing.
I didn't want to replace the broken fishing line I had, as it was expensive and I would have a couple hundred feet of it. I used some string I had laying around the house to print each part on the Y axis, and they came out pretty good. I printed most at 40% infill, since I found that to be pretty strong for most applications. I went on ebay and picked up everything I needed for about 20 bucks shipped.
I have the Printrbot Simple 2014. I've come across a couple of problems:
I saw a comment on thingiverse. The front piece I printed should be the first version. There's no Rev in the name. I think if you shift the hole closest to the motor slightly up so the fan mount lines up, that would fix the problem.
You also need longer screws to get it through the fan, block, wood, and fan shroud. I would suggest perhaps tweaking the model a bit so the area the fan mounts on isn't so thick/bulky?
Fan holes do not align
2. Screw that goes into the motor mount are really hard to screw in. I think it would be good to either use shorter screws, or enlarge the holes on the motor mount. I was screwing them in, and about halfway, the right side broke off. It may vary between your infill settings and material, but for those with somewhat brittle plastic, i think it would be good to enlarge the holes just a tiny bit. Until I get some better plastic or find some other solution, I'm not sure how to solve this. Do you guys know a good infill percentage for this piece?
Broken Motor Mount
Left and right parts broke. The left one came off pretty clean, leaving the motor plate smooth. The right one broke midway.
So if you've come across these problems, and you cut off the stock Y axis rubber tube because you couldn't pry it off, and you don't have another 3D printer to print your stuff, I've done a couple things to make it temporarily functional:
1. Remove the bearings and the bearing tie bar. Remember to use blue loctite on the pulley set screws.
2. Wrap the belt around the front so it goes under the motor. You may need to unscrew the front block, move the belt inward nice and tight, and screw it in. You don't need the little filament piece here.
3. Tighten the back belt tension block until the belt no longer slips.
4. Slightly screw in two screws diagonally on the fan. There should be enough friction to keep the fan in place. It's not really tight, but the fan shouldn't really fall out as it doesn't go left/right.
5. For the fan shroud, look in your extra screws that came with the printrbot. Find two of the smallest ones, and screw them in from the fan shroud to the wood (towards the fan). Doesn't really matter which holes, just make sure they're positioned diagonally. Tape can help if you have decent tape.
I'm printing a test pyramid now with this temporary fix and it's doing pretty good.
Here's how the setup looks when you're done:
Some Printr Noob
Postby EddB » 2014-Feb-Sun-02-Feb
There must have been a major design change since the 10/26/2013 model and the 2014. I am using both his x and y upgrades, I am using his gt2 versions and don't have those problems. For the bearing mounts, as on most screw in connectors, I always tap them with the actual screw that will be used before putting them on. If they are too tight, then I will drill them out to the proper size. That way if there is any problems with the fit or the plastic, I know before going on with the build.
A hint for getting the rubber spindles off your motors without destroying them, use a wide tipped flat screwdriver between the motor and the spindle. Work your way around doing this causes stress fractures in the adhesive and it will eventually pop right off (especially super glues, CA does not bend with the rubber, it will pop right off.)
I know it's too late to help with yours. Just a hint for others that want to try it. When doing upgrades, as a general rule I don't alter the original equipment in any way that it can't be returned to original condition.
EddB
Postby evanalmighty » 2014-Feb-Sun-03-Feb
I had the same hole alignment issue on my 2014 simple. I just lined it up with the fan mount and skipped the one that didn't line up. No big deal. As for the Y motor mount, the breaking off issue has more to do with your print settings and quality. 40% infill is plenty, but try rectilinear instead of that honey comb. It also didn't look like your layers are sticking together very well. It should not have broken off clean like that. If you need a new Y motor mount, I can print one and send it to you. Just msg me your address.
evanalmighty
Postby Some Printr Noob » 2014-Feb-Sun-05-Feb
Thanks for the offer evanalmighty, but I was able to print out what I needed :).
Well, mini update. Pics will come later.
Using my makeshift belt Y thing, I printed out another motor piece at 99% infill (100% wouldn't slice for some reason). I didn't bother checking how the screw would fit, but the screw went in quite nicely during installation. I don't know what happened with the first one. I didn't have to press even 1/2 has hard as my first installation piece when screwing in the screws. Everything installed nicely :S. Same 200 micron print and all, just different infill.
Doing a bit of calibration and calibration printing before I try out the new revision of the fan mount. EddB, what screws are you using to attach the fan all the way to the fan shroud?
Also, I followed this instructables which isn't too bad of a guide: http://www.instructables.com/id/Printrb ... n-Upgrade/
How tight should the belt be? I have it so it has around half a cm of movement (when I push it lightly downwards) when the pulley system is in the middle.
Also, I found that the closer my belt got to the end(extruder end) the belt would move slightly towards the inside, and make a slight "struggling" noise that wouldn't appear when it was on the farther side (towards the rear).
Some Printr Noob
Postby Jon Lawrence » 2014-Feb-Sun-14-Feb
Jon Lawrence
Calibration mode.
Postby evanalmighty » 2014-Feb-Sun-16-Feb
I'll be home later today and snap some pics for you. Thanks.
evanalmighty
Postby Some Printr Noob » 2014-Feb-Sun-20-Feb
Right side looks good, left side looks like it slopes. Don't mind the broken bearing block; i need to reprint another one. I think this block provides strength for the motor block, as my 100% infill one just snapped.
Slopes down on the left
Broken motor mount. I don't know whether to blame the printer settings or filament. I think its the latter as the starter filament didn't have these problems. The matterhackers filament seems to be brittler. I'm trying 200c to try to get better stickiness and flow.
Second revision of the front block warped on me, so no screws on the right side of the front block. I think you should just make a ellipse type of shape as it would be a lot more adjustable. Look at the fan mount in the back of this case for a kind of idea I'm talking about.
This allows for screw adjustability and it doesn't require anything complex
Some Printr Noob
Postby Jon Lawrence » 2014-Feb-Sun-21-Feb
Jon Lawrence
Calibration mode.
Postby evanalmighty » 2014-Feb-Sun-21-Feb
This is just to confirm what noob is getting. I personally don't think it's that big of a deal. Also ignore my fiesta themed Y belt upgrade parts. Not sure how I ended up with red green and white parts.
evanalmighty
Postby EddB » 2014-Feb-Sun-22-Feb
EddB
Postby Some Printr Noob » 2014-Feb-Sun-22-Feb
I had to cut the bearing tie bar because it wouldn't quite fit onto the newly printed motor piece.
I am having problems where the belt slides toward the end of the pulley, and causes the whole y axis to jam. How do I fix this?
Some Printr Noob
Postby plexus » 2014-Feb-Sun-23-Feb
Postby Jon Lawrence » 2014-Feb-Mon-09-Feb
I have put together a cleaner version for models after Jan. 15, 2014 where the fan mount is included in the Y frame.
If you try it out, please let me know how it goes. If successful, I will add to Thingiverse.
BeltEndBlockGT2Front-2014.STL
Jon Lawrence
Calibration mode.
Postby evanalmighty » 2014-Feb-Mon-10-Feb
Thanks Jon. I'll print one up today.
evanalmighty
Postby pantseatflyer » 2014-Feb-Mon-15-Feb
Cool! I will print as well!!
BTW. What is the best place to purchase the belt and bearings for the mod?
pantseatflyer
Postby evanalmighty » 2014-Feb-Mon-16-Feb
I think I bought everything on eBay. Everything came out under $20 and I still have a bunch of spare bearings and belts. Could have been even cheaper with overseas sellers but I didn't want to wait.
evanalmighty
Postby Jon Lawrence » 2014-Feb-Mon-16-Feb
Jon Lawrence
Calibration mode.
Postby Some Printr Noob » 2014-Feb-Mon-16-Feb
I got my belt and bearings and pulleys cheap on ebay.
I picked up belt and pulley from the seller sidewinderinc. 2 feet of belt is enough for both x and y.
I got my bearings from the seller irvineman.
They're really inexpensive. It's like 4 bucks per pilley, and 3 bucks for a foot or two of belt.
All us sellers and the stuff that comes works pretty well.
Some Printr Noob
Postby Some Printr Noob » 2014-Feb-Tue-03-Feb
Well, since noone responded with their tests, I printed one out at 200 microns, 40% infill.
This thing is an awesome piece. Fit perfectly. So much less bulk! The fan is mounted just like it normally does in its stock configuration. No need for any extra screws. The screws fit as they're supposed to, and the belt looks much more level.
Here, you can see the belt is nice and straight throughout the drive. Bulky pieces are sitting on the printbed.
Close up:
If you have the old versions, you will need to cut off a little bit of belt. ~1.5cm or more.
I did some quick Y movement tests and so far it looks good. I'll run a print and see if any problems occur.
Some Printr Noob
Postby Jon Lawrence » 2014-Feb-Tue-08-Feb
Jon Lawrence
Calibration mode.
Postby evanalmighty » 2014-Feb-Tue-10-Feb
Sorry I did print the part last night but I was already in a middle of making a hot bed so I wanted to print some abs before making the switch. The piece looks like it'll fit perfectly from what I can tell.
evanalmighty
Postby Some Printr Noob » 2014-Feb-Tue-11-Feb
I printed two lego pieces, positioned to get as much Y-axis movement as possible.
I'm happy to report that the new front belt block seems to work flawlessly. I don't get any belt jamming and the bearings don't collide with anything.
Some Printr Noob
Postby EddB » 2014-Feb-Tue-17-Feb
In case you want to keep your belts long for future upgrades, I found a little trick to use on the tension block. Just double over the belt and then slide a piece of tight fitting shrink tubing over it. With belt in as close as possible to the locked in position and no tension on the tension block, shrink the tubing (not too much heat as you might damage the belt!)
Been running it for about a week and the belt is still taught! I still have a lot of belt for a future upgrade.
EddB
Postby pantseatflyer » 2014-Feb-Wed-10-Feb
Purchased all materials for X and Y upgrade. Printing parts this evening.
What is best to install first X or Y separately to tweak individually or install at same time?
pantseatflyer
Postby Jon Lawrence » 2014-Feb-Wed-10-Feb
Jon Lawrence
Calibration mode.
Postby evanalmighty » 2014-Feb-Wed-13-Feb
Success
evanalmighty
Postby Delranon » 2014-Feb-Wed-13-Feb
Can also confirm - works perfectly
Thank you very much
Delranon
Postby pantseatflyer » 2014-Feb-Fri-01-Feb
One more piece to print...
pantseatflyer
Postby Some Printr Noob » 2014-Mar-Sat-04-Mar
I got parts to upgrade the X axis to the belt as well!
You may have to grind down some of the wood as a screw on the end stop will scrape against the plate.
The motor piece is a very, very tight fit. My Printrbot Simple was pretty well calibrated before this mod, and I still had some fitting issues. The inner motor circle didn't quite line up, so I took a dremel and shaved off the inside as well. After some fiddling and reassembly, I got it in.
I'm stuck on how to put the X belt end and X belt end mirror onto the build plate. I could force it onto there, but it would likely snap a lot of the plastic. Is there any tricks/tips, or is it just a one piece "slip" on?
Some Printr Noob
Postby thawkins » 2014-Mar-Sat-09-Mar
You have the xcarriage bed plate upside down, the belt left and right mounts go on the other side.
Postby evanalmighty » 2014-Mar-Sat-10-Mar
If I remember correctly you have to flip the bed. Even then you'll have some clearance issue with the end switch.
evanalmighty
Postby Jon Lawrence » 2014-Mar-Sat-10-Mar
Also, before you complete the assembly of the bottom plate, thread the belt around the motor pulley. It's a pain to do after everything is assembled.
Jon Lawrence
Calibration mode.
Postby Some Printr Noob » 2014-Mar-Sat-15-Mar
Wait, I technically did flip the bed...
The area where the locknuts were supposed to go now face upward, and the large endstop cutout is still on the left side.
:S I was just wondering how to put on the belt ends.
Some Printr Noob
Postby evanalmighty » 2014-Mar-Sat-16-Mar
Not that kind of flip. Flip as in keep the lock nuts on the bottom side still, but turn the plate 180 so that the 2 mounts where the string and string tensioner go are now away from the printer instead of being up against the X motor.
evanalmighty
Postby Some Printr Noob » 2014-Mar-Sat-17-Mar
The only proble I see with that is the plate will not fit and scrape against the endstop's screw. I'll have to find another way to mount it or do some dremmel work so that the endstop cutout extends all the way across the bed.
Some Printr Noob
Postby Some Printr Noob » 2014-Mar-Sat-18-Mar
Ok, I'm really confused now :/.
I'm following pictures here:
https://thingiverse-production.s3.amazo ... T2revB.PDF
Tabs are supposed to face out, so there can be only two orientations.
And the only way I can see to have the plate in that orientation is to flip the plate over, and have the locknut engraved cuts on top. This fits nicely, and doesn't require that much modding of the plate. A simple hole drilled and a bit of grinding.
But everyone here is telling me to just take the plate and rotate it 180 degrees. This will require grinding as it doesn't fit in its current state. It just doesn't make sense to orient the bed this way.
And of course, I still have the same problem of how to put the pieces on the end. Do I just force them on?
Some Printr Noob
Postby EddB » 2014-Mar-Sat-21-Mar
EddB
Postby evanalmighty » 2014-Mar-Sat-22-Mar
I also removed the 2 M2 bolts that held down the X end switch and super glued it down to the wood.
evanalmighty
Postby thawkins » 2014-Mar-Sun-00-Mar
Postby EddB » 2014-Mar-Sun-01-Mar
EddB
Postby Some Printr Noob » 2014-Mar-Sun-07-Mar
Well, I somewhat completed the X axis today. Quite tiring. I would suggest doing a little bit over 2-3 days.
The belt wouldn't stay in the belt tensioner ends for some reason. This really pissed me off and I ended up super glue-ing them. Unfortunately one side is off/slanded and I might have to buy more belt and print more pieces.
Also, I had a problem of the X axis being limited due to the x belt ends hitting onto the main carriage of the printrbot itself. I had to grind some material off. Jon, you may want to look into making this area a bit shorter.
Second problem I believe is related to the 2014 simple or the one with the side fan mount. The top of the x belt end will hit both the fan and the wooden area around the fan. Obviously, only one side really needs to be fixed, but I suppose you could mirror it so it's nice and symmetrical.
It took quite a long time, but my Simple is back up and running.
Some Printr Noob
Postby evanalmighty » 2014-Mar-Sun-11-Mar
I think your calibration was a little bit off when you printed these parts. Everything seems to point towards your parts coming out too big. I also have the 2014 but everything cleared fine except for the X stop.
evanalmighty
Postby Some Printr Noob » 2014-Mar-Sun-14-Mar
Some Printr Noob
Postby pantseatflyer » 2014-Mar-Mon-00-Mar
After I flashed my card to fix some stepper motor issues, I thought I had reentered all specs successfully. Well that was until I printed out the last piece of my Y GT2 mod.
The uncalibrated piece is on the right.
[img]http://img.tapatalk.com/d/14/03/03/emuba7an.jpg[/img]
Uncalibrated piece is flimsy as well.
[img]http://img.tapatalk.com/d/14/03/03/udy5egeh.jpg[/img]
You have to check each axis using tape or pencil marks using RetireeJay's calibration. When I calculated mine, I was waaaay off.
pantseatflyer
Postby dmaxx67 » 2014-Mar-Mon-11-Mar
I initially calibrated mine with pencil marks and digital calipers. Last night before I started printing pieces for this mod I used a dial indicator and found I was dead on. Extruder motor I still used calipers.
dmaxx67
Layer 100 of 1234
Postby Some Printr Noob » 2014-Mar-Tue-03-Mar
For my calibration, I usually do a dot on the bed's masking tape, move the head 50mm or so, and then make another dot where the printhead is. I then calculate the number of steps for that axis.
Then I print out the 25mm calibration steps object on thingiverse, and use my digital calipers to measure each axis. I then calculate and enter the new values into the printer.
I did a 10 hour print just fine with the X and Y belt mods. Thanks for all your work Jon.
I think my delrin nut that controls the whole Z movement and y assembly is wearing. Theres a little bit of slop in the nut, and I'm starting to get Z ribbing :S.
Some Printr Noob
Postby dmaxx67 » 2014-Mar-Tue-12-Mar
What sliver settings did you use to print these pieces and how long did they take by chance?
dmaxx67
Layer 100 of 1234
Postby Some Printr Noob » 2014-Mar-Tue-12-Mar
I did mine at 200 microns, with 100% infill on the motor blocks and 40% elsewhere. My layer adhesion is spotty and my filament is brittle.
Most parts took an hour or so.
Some Printr Noob
Postby dmaxx67 » 2014-Mar-Tue-14-Mar
Man either I'm doing something wrong or my simple speed wise sucks.
dmaxx67
Layer 100 of 1234
Postby Jon Lawrence » 2014-Mar-Tue-14-Mar
Jon Lawrence
Calibration mode.
Postby dmaxx67 » 2014-Mar-Tue-22-Mar
Jon could you screenshot a few of your slicer setting pages for me and either me or post them up. I have had a few pieces that did not adhere together very well. I think my terrible spool holder is causing to much drag y chassis when its needs to pull causing my nozzle not to lay correctly on certain layers.
Also I am really torn between your later y mod with carriage and all and kungfuroy version with bowden. I really want to go bowden but i have direct drive and all the direct drive bowden setups are made for stock chassis. Any suggestions on which way to go or maybe I have missed something in all my searching...if i havent missed saomething maybe a later y mod with bowden setup from you...
Anyways any help appreciated
dmaxx67
Layer 100 of 1234
Postby Some Printr Noob » 2014-Mar-Tue-23-Mar
I use this and it works great.
https://www.thingiverse.com/thing:118559
Some Printr Noob
Postby Jon Lawrence » 2014-Mar-Wed-12-Mar
Jon Lawrence
Calibration mode.
Postby Skrotus » 2014-Mar-Wed-19-Mar
I can't get the folded belt through the belt tensioners, everything else fits so I don't think it's my calibiration settings. Any ideas what I might be doing wrong?
Skrotus
Postby Jon Lawrence » 2014-Mar-Wed-19-Mar
Jon Lawrence
Calibration mode.
Postby dmaxx67 » 2014-Mar-Wed-19-Mar
I just started on a fresh roll of Sainsmart filament so i guess i need to play with temp settings like you said. I did measure thickness and type average in Slic3r. Also checked extruder calibration.
I would like your later y mod with this bowden hot end(thing:217094). If at all possible and not a hassle maybe the motor plate from your first GT2 y axis mod with the later y mod end pieces...I'm not sure my printer can print that beautiful carriage form your late y mod with precision quite yet.
And then maybe a Paypal donation your way if you could incorporate a mount for my new inductive switch(http://www.ebay.com/itm/350900159799?ss ... 1439.l2649).
Cooking dinner for kids and wife so Ill post pics soon of my new aluminum bed and inductive switch.
dmaxx67
Layer 100 of 1234
Postby Jon Lawrence » 2014-Mar-Wed-20-Mar
Jon Lawrence
Calibration mode.
Postby dmaxx67 » 2014-Mar-Sat-17-Mar
Jon i am going to use KissSlicer now with Pronterface. I've had enough of slicer and Repetier Host. Would you be able to send me your kisslicer settings? Also the guys who watch this thread are ya able to print from computer or do you have to use sd card. Cause mine always fails within a minute or so of printing from computer but if i run sd card no problems.
dmaxx67
Layer 100 of 1234
Postby evanalmighty » 2014-Mar-Sat-19-Mar
Does it do that with all prints or just these parts?
evanalmighty
Postby dmaxx67 » 2014-Mar-Sat-20-Mar
All prints since the day i got it.
dmaxx67
Layer 100 of 1234
Postby EddB » 2014-Mar-Sat-20-Mar
EddB
Postby Jon Lawrence » 2014-Mar-Mon-07-Mar
Jon Lawrence
Calibration mode.
Postby dmaxx67 » 2014-Mar-Mon-09-Mar
Appreciate you looking into it. I am going to build your x upgrade and then probably just go ahead with your y upgrade.
dmaxx67
Layer 100 of 1234
Postby jwiede » 2014-Mar-Mon-13-Mar
I've got the Y-axis mod installed as from Thingiverse, sole exception is that I'm using EvanAlmighty's "lightning-bolt-shaped" anchor at the head-end, because my Simple2014 has fan and vent shroud in the way otherwise. It's been working fine since install, I'll put up some pictures here in a bit.
Meanwhile, I'm getting ready to do the X-axis mod, and keeping my eyes open for improvements over the "stock" Thingiverse version that might be needed for Simple2014 differences from prior Simple units. I'm not seeing any so far, but need to read the thread more carefully. I've already got the motor plate printed, along with the bearing caps, just waiting on the anchors until certain there weren't changes needed to work with Simple2014.
Jon & Evan, thanks again so much! I just "trust" the drive system so much more using toothed belts and gears versus line and sandpaper pulleys. I'm quite glad to see Printrbot has decided to go with GT2 belt drive by default for the "new" (metal) Simple as well -- shame they didn't have that realization before Simple2014 design was finalized. OTOH, the mods didn't require that much work, and it did "personalize" my printer a bit, so... (shrug).
John W.
jwiede
Postby Some Printr Noob » 2014-Mar-Sun-09-Mar
Little bit of an update.
The white plastic I was using before had crappy layer adhesion. I got some new plastic and this stuff works much, much better. Just redid my X axis because it was a crippling sight due to a broken belt end.
Before:
After:
Problems that I have occured when installing new parts:
- No picture, but I'll try to explain it. Motor mounting piece fit to the plywood around it just fine, but the motor mounting area is very finnicky. I suggest that you kind of create a chamfer-ed or beveled edge on the side of semicircle that touches the motor. My piece wouldn't really fit, as the hole was a hair bit too small and the motor's circle around the shaft seems to be so very slightly angled.
- Belt End still colliding with the fan area.
I can't use around the first centimeter height around the X=100 Y=100 corner. It bumps the fan or the wooden part with the fan. Perhaps you could extend the belt end outwards a little bit or something?
Gonna do the Y axis now, as parts are cracking due to the disappointing quality of my white filament. I would like to try the no-sag Y axis mod, but I'll wait for an update to solve the lack of a fan mount.
Some Printr Noob
Postby EddB » 2014-Mar-Sun-14-Mar
EddB
Postby Some Printr Noob » 2014-Mar-Sun-17-Mar
Some Printr Noob
Postby dmaxx67 » 2014-Mar-Sun-22-Mar
I have tried to print your bed pieces for days with no success. In the one picture you can see it shifted. Is this belt slippage, slicer error, motor current to low? I did notice that before this happened the y axis went all the way opposite of piece and came back and started again.
First pic, what do I need to do for better corners. Running no more than 20mm speed. The opposite side just like it looks beautiful.
Any help would be aprrecuated. I really any to install this upgrade but it's killing me lol.
dmaxx67
Layer 100 of 1234
Postby Some Printr Noob » 2014-Mar-Mon-01-Mar
Some Printr Noob
Postby jwiede » 2014-Mar-Mon-04-Mar
I'm running into a slightly different issue installing the GT2 X mod into my Simple2014: After rotating the bottom bed carriage piece 180deg (so the "open tabs" where the line used to go are in front), the part of the bed carriage at the top is now rubbing against the motor's drive pin (and that's as-is without pulley installed yet). I'm just doing a dry-fit run of stuff -- figured I can try setting motor back slightly during the pulley mounting, etc. or just shave down the top of the bed carriage to make some clearance when I do the actual assembly.
Anyone else run into the problem of the flipped bed carriage plate (the one the rods zip-tie into) rubbing against the motor drive rod? If so, how did you fix?
John W.
jwiede
Postby Jon Lawrence » 2014-Mar-Mon-09-Mar
I have had some requests from people having difficulty getting good prints on their string drive. In response I have uploaded a 2014 version to Shapeways. Shapeways calculates cost on a volume basis. In order to bring the pricing more inline, I hollowed out the parts. There should be no loss of strength since their White Strong & Flexible material is stronger than most PLA prints.
I hope this helps those struggling to get good prints.
Below are the links:
http://shpws.me/rbxt
http://shpws.me/rbxE
Jon Lawrence
Calibration mode.
Postby dmaxx67 » 2014-Mar-Mon-13-Mar
alright i replaced both strings with 65 lb fish line. Tightened the hell out of them and am building the pieces again. Hoping for the fifteenth try is the charm.
dmaxx67
Layer 100 of 1234
Postby jwiede » 2014-Mar-Mon-14-Mar
Jon, is it "normal" for the back edge of the bed carriage closest to the motor (carriage is the one that gets rotated 180deg so the "open tabs" are at the front of the printer post-mod) to rub against the drive shaft of the motor, at least in a 2014 Simple? If so, what's the recommended fix?
John W.
jwiede
Postby Jon Lawrence » 2014-Mar-Mon-14-Mar
Jon Lawrence
Calibration mode.
Jon Lawrence
Calibration mode.
Postby jwiede » 2014-Mar-Mon-18-Mar
John W.
jwiede
Next
