Printrbot Talk Forum • View topic - Slipping Z axis?
Slipping Z axis?
Slipping Z axis?
Postby bringho » 2013-Jul-Sun-15-Jul
I've started printing 8-)
The first print was the 5mm Calibration Cube Steps by MCroucher from Thingverse (thing:24238) and though it did not come out looking great it was a sucessful first print.
It was done using the instructions in the online Simple Getting Started Guide and it looks like I need to add a fan to cool the part being printed.
I later found out that I had inserted the wrong filament diameter into Repetier (1 instead of 1.7 because I used a comma instead of a dot as the decimal separator) and have yet to try with the correct setting...
Then I lowered the print height to 0.2 and added support and tried to print out the Printrbot Simple Bed Leveling Screws by JohnSL from Thingverse (thing:103519) but that did not work out well so I reversed to 0.3 layer height and even though the control over the support feels strange I managed to get a second print that I could clean out quite easily so those are now installed.
I tried to slice the Harry Potter Gryffindor Crest by Imminentfate from Thingverse (thing:123282), scaled down to 33% of the original but both test prints failed at the start of layer 9 with that layer being moved roughly +20 mm in x axis... No Idea what could be wrong but I've saved the file if anyone is interested to have a look at it.
Then I decided to print the swirly shot glass by profgizmo from Thingverse (thing:36103) and then I found this strange behaviour which I would guess is due to z-axis slipping if it were not for the fact that the shot glass measures almost exactly the expected height?!?
First image shows layer 72 of 148
Secon image sows rougly layer 120 (still of 148 ;)
Any comment appreciated.
“Aut viam inveniam aut faciam”
bringho
Slipping Z axis?
Re: Slipping Z axis?
Postby Tdeagan » 2013-Jul-Sun-18-Jul
My first guess would be inadequate current settings for the z steppers.
Wouldn't hurt to lube the lead screws (I use lithium grease.)
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
Quick Change Extruders:
MIC-6 metal bed
Thingiverse Profile:
Tdeagan
Postby bringho » 2013-Jul-Tue-16-Jul
Thanks m8!
I've bought and applied lithium grease but I still have the z-axis problem.
I've found that there are some cables near the z-axis coupling and will take a closer look to ensure that's not the problem before I start adjusting the current which seem to be a pain in the ... on my production Simple.
bringho
Postby Tdeagan » 2013-Jul-Tue-16-Jul
The current adjustment should be easier than it sounds. Each of the motor drivers on the Printrboard has a tiny trim pot.
Use a jewler's flathead screwdriver to turn it (in pretty small increments, say 30 degrees clockwise.) Try out some printing, or even just run the Z axis up and down a number of times. Feel the temp of the Z motor housing. You should be able to increase the current up to the point where the motor starts running hot (which is undesirable.)
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
MIC-6 metal bed
Tdeagan
Postby bringho » 2013-Jul-Wed-12-Jul
Thanks!
Before dismantling the Simple I found out that the controller board is quite simple to get to when the extruder is in top position ;)
I then noticed that the bottom part of the z-coupler (the one connected to the servo) had popped up so the strap did not secure it to the axis... which most certainly is the reason for slippage. I pushed the tube in place again but before I had a chance to test it I managed to break my PSU :x so now I have to repair / get a new PSU before commencing my trials. :cry:
bringho
Postby Tdeagan » 2013-Jul-Wed-17-Jul
Good catch on the troubleshooting. Bummer on the PSU. But, better it fails now than in the last 10 minutes of a three hour print :P (been there.)
good luck!
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
MIC-6 metal bed
Tdeagan
Postby bringho » 2013-Aug-Fri-17-Aug
My new (expensive) 'VOLTCRAFT ' 8.5 amps PSU arrived the other day and I've been doing some more testing :D
Slipping seem to be a thing of the past with the tube firmly pushed down on the motor axis. 8-)
Link for any European who wants/needs a new/better PSU:
Thanks for all the help !!!
bringho
Postby REPRAP SQUAD » 2013-Aug-Sat-08-Aug
If you guys ever have any probs with the x and y axis I've found that a little shrink wrap helps to grip really well.
Postby MDW » 2013-Aug-Sat-23-Aug
MDW
Postby REPRAP SQUAD » 2013-Aug-Sat-23-Aug
Im refering to slippage on the x and y axis that uses vinyl tubing for the spectra line.
