Is nozzle size 0.4mm?
Postby rsilvers » 2013-May-Fri-19-May
Is the nozzle size 0.4mm?
rsilvers
Re: Is nozzle size 0.4mm?
Postby RetireeJay » 2013-May-Fri-20-May
The Getting Started Guide says that all Printrbots currently ship with 0.4mm nozzles.
The convention for identifying nozzles is based on notches (or "rings") cut into the sides (vertices) of the hexagonal brass "nut".
No notch = 0.5mm
1 notch = 0.4mm
2 notches = 0.35mm
