Printrbot Talk Forum • View topic - What kind of hardware (screws n bolts) does the simple metal
Postby Flordonwrath » 2018-Apr-Sat-06-Apr
Flordonwrath
Re: What kind of hardware (screws n bolts) does the simple m
Postby RetireeJay » 2018-Apr-Sat-07-Apr
You can google "Printrbot simple metal BOM" and find the Bill of Materials easily. It lists all the parts you should have.
And you can go to Printrbot.com and pretty easily find the instructions for assembling the Printrbot Simple Metal Kit. A PDF version is here:
Postby Flordonwrath » 2018-Apr-Sat-08-Apr
Flordonwrath
