Extruder fail
Extruder fail
Postby MICHAELB » 2017-Apr-Sun-19-Apr
I'm printing for the first time. My 20mm cube had a square base but was short; printed it at 185. Using the material the printer came with (simple 2014).
On the second print (different model), the output started looking like angelhair; finer and finer until it stopped extruding. The feeder "click click clicks", telling me it's forcing the material but it won't go through.
What's going on?
MICHAELB
Extruder fail
Re: Extruder fail
Postby RetireeJay » 2017-May-Mon-10-May
There's too much back-pressure and the extruder is jamming. You can search for extruder jam in this forum and find hundreds of hits! You might need a higher extruder temperature to liquefy the plastic better.
