sudden fail - extruder yes, all else no.
Postby mr_smigs » 2017-Feb-Sat-19-Feb
can't figure out what's going on,
literally this morning i printed without fail (Printrbot simple 2014)
then this afternoon, no changes, plugged the printer back in for another print,
and now all i can do is turn the extruder on and off.
none of the motors respond to manual control, and it doesn't respond to print starts.
mr_smigs
Re: sudden fail - extruder yes, all else no.
Postby mr_smigs » 2017-Feb-Sat-21-Feb
update,
tried CURA instead of Repieter... when I hit print, it pre-heats, then the z-axis moves epicly slow...
mr_smigs
Postby RetireeJay » 2017-Feb-Sat-22-Feb
Maybe somehow your EEPROM settings got scrambled. Sending an M502 command will restore "factory defaults". You might need to do some tweaking after that, but it should get you to at least a form of a runnable configuration if that's what happened.
Postby mr_smigs » 2017-Feb-Sun-09-Feb
ok,
in cura, pronterface console,
loaded up,
first Z adjustment (raise) it responded as normal...
then back to slow response.
put in M502
now all responses are slow.
mr_smigs
reset the machine...
M501
< echo:Stored settings retrieved
< echo:Steps per unit:
< echo: M92 X84.40 Y84.40 Z2020.00 E95.00
< echo: M203 X100.00 Y100.00 Z2.00 E14.00
< echo:Home offset (mm):
< echo:PID settings:
< echo:Min position (mm):
< echo:Max position (mm):
< echo: M211 X205.00 Y205.00 Z200.00
mr_smigs
z responds slowly, and like it's going in small steps to get there...
X and Y have no response.
mr_smigs
