The G2 Printrboard: wait and see?
PostPosted: 2017-Feb-Sat-14-Feb
by DavidYon47
The new ARM-based board is in the store, with a good sales pitch to boot. Tempting for a lot of reasons, but the cascading dependencies and limitations are daunting:
  • Need the new hot-end
  • The new hot-end apparently requires upgrading the fan (and perhaps even putting in two fans)
  • You're SOL if you have a heated bed
  • No support for the original LCD
I just finished upgrading to the 4-step Z rod, the gear head extruder, and replaced the X/Y drive belts. That plus some calibration/lubrication has had a major effect on the the printer. So for right now I'm probably going to take a breather.
I've been tempted by the hot end for awhile, and it looks like the kinks have been worked out. Having to rework the cooling situation seems like a pain. But that's not a deal-breaker and would probably be for the better if I could get it on the air.
The LCD is actually pretty handy, not a deal-breaker but I'd miss it.
The heated bed? Now there's something I'm loathe to give up. In theory it could be manually controlled, but I don't have time to reverse-engineer a way to do that, and I haven't been able to find anybody who's posted how it might be done.
But does my list above accurately reflect things? If so, seems like you have to be pretty motivated and/or have lots of tinkering time on your hands.
Re: The G2 Printrboard: wait and see?
PostPosted: 2017-Feb-Tue-20-Feb
by blort
no heated bed and no PB supported solution is a real dealbreaker for me. After sinking the money into the extended axis heated bed I don't really want to go back to tape.
I really want to get in on some of this super quiet stepper operation, increased accuracy at speed and all the jazz that comes with it. I just don't think I can start giving up features while putting new money in.
PostPosted: 2018-Feb-Mon-18-Feb
by brookdrumm
I know it’s an old thread, but thought I’d comment:
The g2 board does have heated bed support- always has, actually. The deal is if you use the cloud, it is not included. The cloud is for pla primarily. Although that feature should be available soon.
Anyway, the g2 board understands regular gcode so you can slice in cura, slicer, whatever and print w cura and repetier... printrun... octoprint but not simplify3d (complify3d ;)
It’s faster, quieter, 32 but arm. But you will need to set up your machine w a starting gcode to run it. It’s a one and done deal.
Brook
PostPosted: 2019-Feb-Fri-00-Feb
by BhamMaddog
Is this board still active? I am trying to resurrect my good ole' Printbot Simple Metal with pretty much every upgrade Brook offered....
PostPosted: 2019-Feb-Fri-07-Feb
by RetireeJay
BhamMaddog wrote:Is this board still active? I am trying to resurrect my good ole' Printbot Simple Metal with pretty much every upgrade Brook offered....
There are a few of us who continue to monitor the forum.
I think you have posted this question in the wrong thread. Your Printrbot Simple Metal probably doesn't have a G2 Printrboard. If it does, very little help is available for you because the G2 design was originally dependent on a "cloud" connection which no longer exists with the demise of Printrbot - although some people have managed to change that behavior.
If you have a Rev D or Rev F board, there are lots more people here who know about that.
PostPosted: 2019-Feb-Fri-13-Feb
by BhamMaddog
I put in the G2 board and have it working with my RaspberryPi......sort of......My Simple Metal is massively upgraded.....X, Z extended, heated bed, Geared extruder, and hotend upgraded (for the board of course).....Also using Zebra plate for a flexible removable bed.....
I am printing upgrade parts for my new Creality Ender 3 Pro.....LOL
Will be looking into building my own firmware to codify all the upgrades and get Simplify3D to output gcode that'll work without cutting and pasting.....
