Auto-Level-Probe-Wires
Postby Woof-! » 2016-Mar-Fri-14-Mar
So, I've purchased an Auto leveling probe and the three wires are black -> Brown -> Blue. Does anyone know which one is Voltage, Ground, and signal?
Woof-!
Re: Auto-Level-Probe-Wires
Postby Woof-! » 2016-Mar-Fri-15-Mar
I think I've found it...
BN(brown) 12V
BK(black) output signal
BL(blue) ground
Woof-!
Postby Mooselake » 2016-Mar-Fri-18-Mar
The probe's data sheet should tell you. There's nothing magic about wire colors. Somebody sat down. said enie meenie, and arbitrarily picked them.
What probe. make, model, source, part number?
And what printer? Printrbot doesn't use RAMPS, although their customers can replace the supplied Printrboard with one
Postby Woof-! » 2016-Mar-Fri-19-Mar
I honestly have no idea what the model is- I bought it off Printerbot's website. It's the same that comes standard on all printerbots I believe- It has a yellow tip.
Woof-!
Postby bbrown64 » 2016-Mar-Sat-06-Mar
The only thing a person needs to know is, which way to hook that probe up correctly. To hook it up correctly align blue wire to black wire and press the connector together.
Bill Brown
Tulsa, OK
bbrown64
Postby Mooselake » 2016-Mar-Sat-08-Mar
Unless you're using a RAMPS board
Postby CPUWiz » 2016-Jul-Sun-16-Jul
Why are the colors reversed?
CPUWiz
Postby Mooselake » 2016-Jul-Mon-08-Jul
If you mean blue and black, just assume that they were randomly assigned. New engineer? Just wanted to be different? Blue's their (most? least?) favorite color?
