Printrbot Talk Forum • View topic - capacitive Sensor for glass bed
Postby festaman » 2015-Aug-Mon-18-Aug
Hey all I ordered a glass bed and what i thought was goign to be the correct sensor but i was shipping the wrong one. Is anyone out there using a capacitive sensor with a glass bed? I am about to order a LJC12A3-H-Z/BX or LJC12A3-H-Z/BY i think they are pretty much the same thing but cant tell for sure.
festaman
Re: capacitive Sensor for glass bed
Postby evanalmighty » 2015-Aug-Mon-18-Aug
These sensors only detect metal, not glass. You can still use your glass bed and place a piece of foil under the glass so that the probe can trigger. You might need to find a probe with longer detection range so that it can trigger before crashing into the glass.
evanalmighty
Postby festaman » 2015-Aug-Mon-20-Aug
There are 2 kinds of sensor that you can use. Inductive that will detect metal which is what comes on the Printrbot. I ordered a capacitive one . They will detect anything near it. The reason for for the new sensor is that if it doenst detect the glass it defeats the purpose of it. If the sensor detects the aluminum underneath then it wont level off the glass surface which could be flatter then the bed under it.
festaman
Postby evanalmighty » 2015-Aug-Mon-20-Aug
That's why the Z offset is adjustable. You'd just increase the Z offset to compensate for the thickness of the glass.
evanalmighty
Postby RetireeJay » 2015-Aug-Mon-21-Aug
Although capacitive proximity sensors can respond to dielectrics like glass, their response sensitivity is likely only 1/3 of the sensing distance for metal. Of course, for glass backed up by metal, the result will be intermediate.
I found this (not the one for the sensor you specified, but perhaps representative). Look at the graphs on page 3
