Print bed porn
Come visit Plexus' print lab and find out what he's been up to (what did he break now?)
Print bed porn
Postby plexus » 2014-Jan-Fri-02-Jan
This is a custom machined MIC6 aluminum head bed, with a QU-BD silicone heater, spring leveled on a 6061 Y platen driven on a PSB low profile linear rail on teflon bronze bushings. stock motor and drive arrangement. This is a detail of the front corner showing the nice brass level thumb screws and hardware.
Print bed porn
Re: Print bed porn
Postby thawkins » 2014-Jan-Fri-02-Jan
plexus wrote:This is a custom machined MIC6 aluminum head bed, with a QU-BD silicone heater, spring leveled on a 6061 Y platen driven on a PSB low profile linear rail on teflon bronze bushings. stock motor and drive arrangement. This is a detail of the front corner showing the nice brass level thumb screws and hardware.
Sheer filth, ought to be banned .......
Where can i get one........
Re: Print bed porn
Postby marmil » 2014-Jan-Tue-23-Jan
Looks deee-lish!
Did you wrap the spring with Teflon?
CG & 3D enthusiast • Printrbot+ Kickstarter backer • Mods: GT2 belts, custom aluminum y-carriage and print bed
marmil
Re: Print bed porn
Postby REPRAP SQUAD » 2014-Jan-Wed-00-Jan
X-bridge porn: custom milled aluminum x axis, rod mounts, y bearing blocks and carriage. PS I like your setup and a custom build with dual mk3 8x8 hbs is in the works.
I must tip my hat to you it truly is a thing of beauty.
http://www.enviousmods.com
Return to Plexus Print Lab
