Printrbot Talk Forum • View topic - Fault or feature?
Fault or feature?
Come visit Plexus' print lab and find out what he's been up to (what did he break now?)
Fault or feature?
Postby plexus » 2014-Jan-Thu-20-Jan
You decide. There are some interesting things going on here...
Fault or feature?
Re: Fault or feature?
Postby RetireeJay » 2014-Jan-Thu-20-Jan
So what was the original model? Was it intended to look like this?
Postby thawkins » 2014-Jan-Thu-21-Jan
Postby plexus » 2014-Jan-Thu-23-Jan
The original model has been attached. It is Taulman 618 nylon
Postby RetireeJay » 2014-Jan-Fri-12-Jan
So you sliced it in vase mode... I guess you used Slic3r, although I know you prefer KISSlicer.
Anyway, I'm guessing that you purposely under-extruded, causing the "blobbiness" where the nylon comes out in increments rather than a smooth continuous stream.
BTW, that model looks pretty tall. You used an extended PB Plus height, right?
Postby Jon Lawrence » 2014-Jan-Fri-13-Jan
Ok so are they ripples (X-Y movement), or changes in thickness?
Jon Lawrence
Calibration mode.
Postby RetireeJay » 2014-Jan-Mon-14-Jan
Another guess...
You used Slic3r in Vase mode, but you also specified a Z-lift and/or a filament retract at every "layer change" - which in vase mode occurs very frequently around the perimeter of the object.
Postby plexus » 2014-Jan-Mon-14-Jan
Answer: out of spec filament. oval. 1.71-1.95mm diameter.
so imagine the possibilities: varying the shape of filament to cause different extrusion characteristics to create different textures.
Postby RetireeJay » 2014-Jan-Mon-18-Jan
Umm...
I thought that once the filament melted, it kinda didn't matter how round it was beforehand. And 1mm of oval filament with a certain cross-section has the same volume as 1mm of round filament with the same cross section. So I'm a little confused here.
Postby plexus » 2014-Jan-Mon-21-Jan
Postby PxT » 2014-Jan-Tue-01-Jan
Protoparadigm has a good article on why consistent roundness matters:
http://www.protoparadigm.com/blog/2011/ ... t-quality/
Postby marmil » 2014-Jan-Wed-00-Jan
+ [color=#BF0000]•
marmil
Postby Jon Lawrence » 2014-Jan-Wed-09-Jan
Could a similar effect be done with an eccentric extruder gear? You would only get one bulge per revolution though.
Jon Lawrence
Calibration mode.
Return to Plexus Print Lab
