Printrbot Talk Forum • View topic - Moving on from the Ubis
Come visit Plexus' print lab and find out what he's been up to (what did he break now?)
Postby plexus » 2014-Jan-Thu-19-Jan
All metal high temp hot end. so far, so good, but not Utopia.
Re: Moving on from the Ubis
Postby thawkins » 2014-Jan-Thu-19-Jan
Which hotend is this?
What is the max temp you can take it up to?
Does it still work with PLA?
Postby plexus » 2014-Jan-Thu-23-Jan
It's an E3D. I can get it to 350C which is the limit the heater can get to. it will sit there at 350C with no smells, nothing burning and the filament guide, metal, luke warm to the touch. It prints PLA with excellent results. The fan cools the fins of the filament guide and is very effective at doing so, even when running at 350C.
Postby MrWasabi » 2014-Jan-Fri-01-Jan
You would use this mainly to print Nylon? New to the game so not sure what the advantages are of going to such temps
MrWasabi
Postby thawkins » 2014-Jan-Fri-02-Jan
Postby plexus » 2014-Feb-Wed-17-Feb
Postby wd5gnr » 2014-Feb-Thu-01-Feb
I am thinking of trying E3D on the Aluminum extruder. Did you have to lengthen the E3D to get it near the bed or is it long enough?
Al Williams
Twitter: @awce_com
wd5gnr
Postby Nickies08 » 2014-Feb-Thu-12-Feb
I have two of the Pico all metal hotends coming with 500C thermistors. http://www.b3innovations.com/shop/pico-ks/
I'm really anxious for then to arrive in March.
Printrbot Plus V2.0
Aluminum bearing blocks
Aluminum Build Plate
Robotdigg custom Nema 17 motors with 500mm T8*8 Acme Rods on Z-axis (19" of print height)
Wire extensions to accommodate extra build height
GT2 Belts and Pulleys
Nickies08
Postby wd5gnr » 2014-Feb-Thu-15-Feb
The Pico looks good. I decided I wanted something cheap for 1.75 ABS and the Ubis is out of stock so I sprung $20 for a J-head lite off eBay. I figure for $20 even if I can't figure out where to mount it, I'll do something with it. The I will eventually go with an E3D, a Pico, or something else that I haven't decided yet.
Al Williams
Twitter: @awce_com
wd5gnr
Postby plexus » 2014-Feb-Thu-21-Feb
Return to Plexus Print Lab
